3 Replies Latest reply on May 31, 2014 6:28 PM by JJMack
    I get white edges when I print a file.
    Tim_Anonymous
      This happens on every printer with every DPI width and height.
      Even if I save the file as PNG to print it with another program it will get white edges.
      Screenshot of example:
      [URL=http://imgur.com/sfGbI69][IMG]http://i.imgur.com/sfGbI69.png[/IMG][/URL]
      <a href="http://imgur.com/sfGbI69"><img src="http://i.imgur.com/sfGbI69.png" title="Hosted by imgur.com" /></a>
        • 1. Re: I get white edges when I print a file.
          You do not show your documents size, printer settings, etc does you printer support border-less printing on the paper being used.  In your screen capture we can not see the setting use other then center. How scaling is being done only you know etc
          • 2. Re: I get white edges when I print a file.
            Tim_Anonymous Level 1
            This is what I found when I was searching for borderless printing. I use an Epson SX130.
            1. Print speed (PPM) when printed on A4 plain paper in the fastest mode. 10x15cm photo print speed when printed on Epson Premium Glossy Photo Paper in draft, borderless mode. Print speed may vary depending on system configuration, print mode, document complexity, software, type of paper used and connectivity. Print speed does not include processing time on host computer
            2. USB cable not supplied in box
            3. Otherwise 3mm top, left, right, bottom
            4. According to ISO7779 pattern with Epson Premium Glossy Photo Paper/Photo RPM mode
            5. According to ISO9296
            The printer settings don't care, if I'd use MS paint it print it alright.
            Here are my other settings.
            http://i.imgur.com/u5qOX8H.png
            I am printing it on A4 size.
            You see these white edges with black rows?
            • 3. Re: I get white edges when I print a file.
              No your printing garbage you need to learn the basics you need more pixels your printing a very small web size  large at a very low 36DPI resolution and you want to print it even bigger.
