2 Replies Latest reply on Jun 1, 2014 7:26 AM by c.pfaffenbichler
    Get gradient color stops data via JavaScript
    venko
      Is there a way to retrieve the Color and Location properties of each color stop in a Gradient Overlay (linear gradients only)?
      I would like to be PS CS5.1/CS6 compatible.
      Thank you.
        • 2. Re: Get gradient color stops data via JavaScript
          c.pfaffenbichler Level 9
          Maybe this helps:
          // check color stops for gradient overlay;
          // based on code by michael l hale;
          // 2014, use it at your own risk;
          #target photoshop
          if (app.documents.length > 0) {
          var ref = new ActionReference();
          ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var thisDesc = executeActionGet(ref);
          if (thisDesc.hasKey(stringIDToTypeID('layerEffects'))) {
          var layerEffects = thisDesc.getObjectValue(stringIDToTypeID('layerEffects'));
          if (layerEffects.hasKey(stringIDToTypeID('gradientFill'))) {
          var gradientFill = layerEffects.getObjectValue(stringIDToTypeID('gradientFill'));
          var gradient = gradientFill.getObjectValue(stringIDToTypeID('gradient'));
          var colors = gradient.getList(stringIDToTypeID('colors'));
          for (var m = 0; m < colors.count; m++) {
          checkDesc2 (colors.getObjectValue(m))
          ////// based on code by michael l hale //////
          function checkDesc2 (theDesc) {
          var c = theDesc.count;
          var str = '';
          for(var i=0;i<c;i++){ //enumerate descriptor's keys
            str = str + 'Key '+i+' = '+typeIDToStringID(theDesc.getKey(i))+': '+theDesc.getType(theDesc.getKey(i))+'\n'+getValues (theDesc, i)+'\n';
          alert("desc\n\n"+str);
          ////// check //////
          function getValues (theDesc, theNumber) {
          switch (theDesc.getType(theDesc.getKey(theNumber))) {
          case DescValueType.BOOLEANTYPE:
          return theDesc.getBoolean(theDesc.getKey(theNumber));
          break;
          case DescValueType.CLASSTYPE:
          return theDesc.getClass(theDesc.getKey(theNumber));
          break;
          case DescValueType.DOUBLETYPE:
          return theDesc.getDouble(theDesc.getKey(theNumber));
          break;
          case DescValueType.ENUMERATEDTYPE:
          return (typeIDToStringID(theDesc.getEnumerationValue(theDesc.getKey(theNumber)))+"_"+typeIDToStr ingID(theDesc.getEnumerationType(theDesc.getKey(theNumber))));
          break;
          case DescValueType.INTEGERTYPE:
          return theDesc.getInteger(theDesc.getKey(theNumber));
          break;
          case DescValueType.LISTTYPE:
          return theDesc.getList(theDesc.getKey(theNumber));
          break;
          case DescValueType.OBJECTTYPE:
          return (theDesc.getObjectValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getObject Type(theDesc.getKey(theNumber))));
          break;
          case DescValueType.REFERENCETYPE:
          return theDesc.getReference(theDesc.getKey(theNumber));
          break;
          case DescValueType.STRINGTYPE:
          return theDesc.getString(theDesc.getKey(theNumber));
          break;
          case DescValueType.UNITDOUBLE:
          return (theDesc.getUnitDoubleValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getUn itDoubleType(theDesc.getKey(theNumber))));
          break;
          default:
          break;
