1 Reply Latest reply on Aug 26, 2015 12:14 AM by abhedk22458412
    Convert numeric in words in adobe forms (start with the currency)
    jocer Level 1
      Hi to all,
      Below script i found here for converting numeric into words and its work perfectly. Just I edit in UAE currency.
      It is possible to move the dirhams (currency) in front like. 1,900,000.55 = Dirhams One Million Nine Hundred Thousand and Fifty Five fils Only. (with period)
      or 1,900,085.55 = Dirhams One Million Nine Hundred Thousand Eight Five and Fifty Five fils.
      Previous code was One Million Nine Hundred Thousand Eighty-Five Dirhams and Fifty-Five Fils
      Thanks in advance
      Much Appreciate your advance help
      aTens = [ "Twenty", "Thirty", "Forty", "Fifty", "Sixty", "Seventy", "Eighty", "Ninety"];
      aOnes = [ "Zero", "One", "Two", "Three", "Four", "Five", "Six", "Seven", "Eight", "Nine",
        "Ten", "Eleven", "Twelve", "Thirteen", "Fourteen", "Fifteen", "Sixteen", "Seventeen", "Eighteen",
        "Nineteen" ];
      function ConvertToHundreds(num)
         var cNum, nNum;
         var cWords = "";
         num %= 1000;
         if (num > 99) {
            /* Hundreds. */
            cNum = String(num);
            nNum = Number(cNum.charAt(0));
            cWords += aOnes[nNum] + " Hundred";
            num %= 100;
            if (num > 0)
               cWords += " and "
         if (num > 19) {
            /* Tens. */
            cNum = String(num);
            cWords += aTens[nNum - 2];
            num %= 10;
            if (num > 0)
               cWords += "-";
         if (num > 0) {
            /* Ones and teens. */
            nNum = Math.floor(num);
            cWords += aOnes[nNum];
         return cWords;
      function ConvertToWords(num)
         var aUnits = [ "Thousand", "Million", "Billion", "Trillion", "Quadrillion" ];
         var cWords = (num >= 1 && num < 2) ;
         var nRight = Math.floor(num);
         for (var i = 0; nLeft > 0; i++) {
             if (nLeft % 1000 > 0) {
                if (i != 0)
                   cWords = ConvertToHundreds(nLeft) + " " + aUnits[i - 1] + " " + cWords;
                else
                   cWords = ConvertToHundreds(nLeft) + " " + cWords;
             nLeft = Math.floor(nLeft / 1000);
         num = Math.round(num * 100) % 100;
         if (num > 0)
            cWords += ConvertToHundreds(num) + " Fils";
         else
            cWords += "Zero Fils";
         return cWords;
