11 Replies Latest reply on May 21, 2007 4:04 AM by voguecreative
    Pool Game
    voguecreative
      Hey. Im having no luck whatsoever in creating a snooker game in Director. I have created all the images for tables etc and began to code the script.
      The game is basically a one ball snooker game with the aim of potting the ball in any pocket. I have two sprites (ball and cue).
      The game runs like this.
      The user moves the mouse which rotates the cue around the ball - DONE
      The user clicks the mouse to set the cue in place - DONE
      The user presses SPACE BAR and the ball travels in the direction the cue is facing towards. - THIS IS WHERE I AM HAVING PROBLEMS
      so far my code looks like this:
      [code]
      function exitframe(me) {
      _global.angle1 = Math.atan((_mouse.mouseV-sprite("cue").locV )/(_mouse.mouseH-sprite("cue").locH ))
      if (_mouse.mouseH < sprite("cue").locH) {
      sprite("cue").rotation = _global.angle1*180/Math.PI -90
      else {
      sprite("cue").rotation = _global.angle1*180/Math.PI +90
      function beginsprite(me) {
      cuelock = 0
      if (cuelock == 0) {
      else {
      if ((cuelock == 1) && (_key.keyPressed(49)) && (_mouse.mouseH < sprite("cue").locH)) {
      sprite(2).loch = _global.angle1*180/Math.PI +90
      sprite(2).locv = _global.angle1*180/Math.PI +90
      else {
      sprite(2).loch = _global.angle1*180/Math.PI -90
      sprite(2).locv = _global.angle1*180/Math.PI -90
      function mouseup(me) {
      cuelock = 1
      function rightmouseup(me) {
      cuelock = 0
      [/code]
      Can anyone help me finish this off asap as its driving me crazy...seriously i wake up in the night with visions of pool tables and angles and maths....
      Im willing to negotiate a reward for anyone who can help me complete this game. It needs to be in Javascript for Director MX04 as that is the software im comfortable using.
      Tom
        • 1. Re: Pool Game
          Level 7
          > code the script.
          > _global.angle1 =
          > Math.atan((_mouse.mouseV-sprite("cue").locV)/(_mouse.mouseH-sprite("cue").locH
          For a start, I'd use Math.atan2 to avoid the hassle of checking which
          quadrant it was in, and the otherwise messy case of
          _mouse.mouseH==sprite("cue").locH, which would lead to a division by zero
          error (unless Math.atan understands INF).
          Andrew
          • 2. Re: Pool Game
            voguecreative Level 1
            Hi. Thanks for your help, but i am still unable to send the ball along the angle of the cue?
            • 3. Re: Pool Game
              Level 7
              I didn't see any code in your OP for moving the cue ball...
              Andrew
              • 4. Re: Pool Game
                else {
                This is the code to move the ball on the press of space bar
                • 5. Re: Pool Game
                  Level 7
                  > else {
                  Ah, see, you're not actually /changing/ the position of the ball (presumably
                  in sprite(2)) with that code, you're just setting it to one value.
                  Perhaps the following would be helpful to you:-
                  Animation maths in Lingo:
                  http://www.jmckell.com/
                  Pool physics:
                  http://www.gamasutra.com/features/20020118/vandenhuevel_01.htm
                  (You will have to register (free) if you're not already registered.)
                  A pool demo using the Havok xtra in Director:
                  http://director-online.com/havok/demos/demo-pool.html
                  Andrew
                  • 6. Re: Pool Game
                    Thank you for your help Andrew it is greatly appreciated. However all i require is the code that allows the cue ball sprite to move 100px in the direction the cuestick is facing..
                    • 7. Re: Pool Game
                      Level 7
                      Add 100*cos(theta) to x and 100*sin(theta) to y, where theta is the angle
                      the cue is facing (in radians). Don't forget that Director's y-axis is
                      upside-down.
                      Andrew
                      • 8. Re: Pool Game
                        Cheers mate. How do i get the angle the cue is facing?
                        • 9. Re: Pool Game
                          Level 7
                          Isn't that what your angle1 variable is referring to?
                          Andrew
                          • 10. Re: Pool Game
                            if ((cuelock == 1) && (_key.keyPressed(49))) {
                            sp = sprite(2)
                            sp.loch = Math.sin(_global.angle1) * 100
                            sp.locv = Math.cos(_global.angle1) * 100
                            This code works but the ball does not go off at the correct angle....
                            • 11. Re: Pool Game
                              quote:
                              sp = sprite(2)
                              Any suggestions?
