10 Replies Latest reply on Jun 3, 2014 1:35 AM by Chinnadk
    Auto create paragraph styles and properties
    ASHOK KUMAR Level 1
      Dear All
      I had created Two paragraph styles using with below script. Now I have set in H1 All properties (like Basic Character Formats (font, font size, leading, tracking, kerning, Indent and spacing, Tabs, Paragraph rules, Keep option and all of paragraph style Options). It is possible to fix. Totally I will have creat 60 to 70 styles.
      Thanks in advance
      The code is:
      var doc = app.activeDocument;
      var array = ["H1", "H2"];
      for(var i=0;i<array.length;i++)
          try{
              doc.paragraphStyles.add({name:array[i]});
          catch(e)
                      alert("'" + array[i] + "'" + "already exists in the document.")
      ASHRAM
        • 1. Re: Auto create paragraph styles and properties
          Chinnadk Level 4
          Hi Ashram,
          Try this.
              try{
                  var pstyle = doc.paragraphStyles.add({name:array[i]});
                  with(pstyle) //Change the below lines as per your requirement
                          appliedFont = "Arial";
                          pointSize = 12;
                          leading = 15;
                          tracking  = 100
              catch(e)
          • 2. Re: Auto create paragraph styles and properties
            ASHOK KUMAR Level 1
            Hi Chinna
            Thanks for your code.
            Now It's working fine. But I will have creat 60 to 70 styles in different fonts and size, leading etc...
            Each styles I will have create separate code?
            ASHRAM
            • 3. Re: Auto create paragraph styles and properties
              ASHOK KUMAR Level 1
              Hi Chinna
              I like set Paragraph properties near in particular style.
              like:
              var array = ["H1, font:______, font style: _______, tracking______, leading_____ etc", "H2, font:______, font style: _______, tracking______, leading_____ etc"];
              It is possible Chinna?
              ASHRAM
              • 4. Re: Auto create paragraph styles and properties
                Chinnadk Level 4
                Try this.
                    try{
                          if(array[i] == "H1"){
                              doc.paragraphStyles.add({name:array[i], appliedFont:"Arial", pointSize:12, leading:15});
                          if(array[i] == "H2"){
                              doc.paragraphStyles.add({name:array[i]}, appliedFont:"Minion", pointSize:10, leading:12);
                    catch(e)
                Regards,
                Chinna
                • 5. Re: Auto create paragraph styles and properties
                  ASHOK KUMAR Level 1
                  Hi Chinna
                  It is OK . But H1 and H2 applied in Same font style, size and leading.
                  This style have been different font size, font style, leading, color and etc..
                  Example :
                  H1 = appliedFont:"Arial", pointSize:12, leading:15 . . . .
                  H2 = appliedFont:"Times", pointSize:10, leading:13 . . . .
                  H3 = Different font, font style, point size, leading .....
                  H4 = Different font, font style, point size, leading .....
                  Bull list = Different font, font style, point size, leading .....
                  Num list = Different font, font style, point size, leading .....
                  etc.
                  Totally in 60 to 70 styles.
                  How to fix other styles ?
                  ASHRAM
                  • 6. Re: Auto create paragraph styles and properties
                    Chinnadk Level 4
                    Hi ASHRAM,
                    It is working fine here. Just try again.
                        try{
                                  doc.paragraphStyles.add({name:array[i], appliedFont:"Minion", pointSize:10, leading:12});
                        catch(e)
                    Regards,
                    Chinna
                    • 7. Re: Auto create paragraph styles and properties
                      ASHOK KUMAR Level 1
                      Hi Chinna
                      I did use above code the following error was found.
                      After I check and use below code. It's working fine chinna.
                          try{
                          catch(e)
                      It is OK Chinna...?
                      ASHRAM
                      • 8. Re: Auto create paragraph styles and properties
                        ASHOK KUMAR Level 1
                        Hi Chinna
                        Thanks for your effort ... Thanks
                        ASHRAM
                        • 9. Re: Auto create paragraph styles and properties
                          ASHOK KUMAR Level 1
                          Hi Chinna
                          How to code Paragraph style Options all properties.
                          Example:
                          pointSize = 12;
                          leading = 15;
                          tracking  = 100
                          spaceAbove = "10mm";
                          spaceBelow = "10mm";
                          etc.....
                          ASHRAM
