0 Replies Latest reply on Jun 3, 2014 4:22 PM by dimi.gobbo
    Photoshop CC Photomerge issue
    dimi.gobbo
      Since last update of Photoshop CC, I can not user Photomerge to do my Panoramic images.
      Every time a try to do it, my PC freezes, the hard-drive go 100% and, after it comes back, Photoshop is Not Responding.
      My System Info from Photoshop
      Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
      Operating System: Windows 8 64-bit
      Version: 6.2
      System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
      Physical processor count: 4
      Processor speed: 3093 MHz
      Built-in memory: 8153 MB
      Free memory: 5172 MB
      Memory available to Photoshop: 7115 MB
      Memory used by Photoshop: 60 %
      Image tile size: 0K
      Image cache levels: 0
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Display Bounds: top=0, left=0, bottom=1080, right=1920
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGPUs=1
      gpu[0].OGLVersion="3.0"
      gpu[0].MemoryMB=1024
      gpu[0].RectTextureSize=16384
      gpu[0].Renderer="GeForce GT 640/PCIe/SSE2"
      gpu[0].RendererID=4032
      gpu[0].Vendor="NVIDIA Corporation"
      gpu[0].VendorID=4318
      gpu[0].HasNPOTSupport=1
      gpu[0].DriverVersion="9.18.13.3788"
      gpu[0].Driver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
      gpu[0].DriverDate="20140519000000.000000-000"
      gpu[0].CompileProgramGLSL=1
      gpu[0].TestFrameBuffer=1
      gpu[0].OCLPresent=1
      gpu[0].OCLVersion="1.1"
      gpu[0].CUDASupported=1
      gpu[0].CUDAVersion="6.0.1"
      gpu[0].OCLBandwidth=6.26356e+010
      gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
      gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
      gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
      gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
      gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
      gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
      License Type: Subscription
      Serial number: 96040703155199386489
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
      Temporary file path: C:\Users\Dimitry\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 1,81T, 1,21T free
      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
      Installed components:
         ACE.dll   ACE 2013/10/29-11:47:16   79.548223   79.548223
         adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
         AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
         AdobeOwl.dll   Adobe Owl 2013/10/25-12:15:59   5.0.24   79.547804
         AdobePDFL.dll   PDFL 2013/10/29-11:47:16   79.508720   79.508720
         AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1786
         AdobeXMP.dll   Adobe XMP Core 2013/10/29-11:47:16   79.154911   79.154911
         AdobeXMPFiles.dll   Adobe XMP Files 2013/10/29-11:47:16   79.154911   79.154911
         AdobeXMPScript.dll   Adobe XMP Script 2013/10/29-11:47:16   79.154911   79.154911
         adobe_caps.dll   Adobe CAPS   7,0,0,21
         AGM.dll   AGM 2013/10/29-11:47:16   79.548223   79.548223
         ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
         aif_core.dll   AIF   5.0   79.534508
         aif_ocl.dll   AIF   5.0   79.534508
         aif_ogl.dll   AIF   5.0   79.534508
         amtlib.dll   AMTLib (64 Bit)   7.0.0.249 BuildVersion: 7.0; BuildDate: Thu Nov 14 2013 15:55:50)   1.000000
         ARE.dll   ARE 2013/10/29-11:47:16   79.548223   79.548223
         AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
         AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
         Bib.dll   BIB 2013/10/29-11:47:16   79.548223   79.548223
         BIBUtils.dll   BIBUtils 2013/10/29-11:47:16   79.548223   79.548223
         boost_date_time.dll   DVA Product   7.0.0
         boost_signals.dll   DVA Product   7.0.0
         boost_system.dll   DVA Product   7.0.0
         boost_threads.dll   DVA Product   7.0.0
         cg.dll   NVIDIA Cg Runtime   3.0.00007
         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
         CIT.dll   Adobe CIT   2.1.6.30929   2.1.6.30929
         CITThreading.dll   Adobe CITThreading   2.1.6.30929   2.1.6.30929
         CoolType.dll   CoolType 2013/10/29-11:47:16   79.548223   79.548223
         dvaaudiodevice.dll   DVA Product   7.0.0
         dvacore.dll   DVA Product   7.0.0
         dvamarshal.dll   DVA Product   7.0.0
         dvamediatypes.dll   DVA Product   7.0.0
         dvaplayer.dll   DVA Product   7.0.0
         dvatransport.dll   DVA Product   7.0.0
         dvaunittesting.dll   DVA Product   7.0.0
         dynamiclink.dll   DVA Product   7.0.0
         ExtendScript.dll   ExtendScript 2013/10/30-13:12:12   79.546835   79.546835
         FileInfo.dll   Adobe XMP FileInfo 2013/10/25-03:51:33   79.154511   79.154511
         filter_graph.dll   AIF   5.0   79.534508
         icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
         icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
         imslib.dll   IMSLib DLL   7.0.0.145
         JP2KLib.dll   JP2KLib 2013/10/29-11:47:16   79.248139   79.248139
         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
         libiomp5md.dll   Intel(R) OMP Runtime Library   5.0
         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         LogSession.dll   LogSession   2.1.2.1785
         mediacoreif.dll   DVA Product   7.0.0
         MPS.dll   MPS 2013/10/29-11:47:16   79.535029   79.535029
         msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.8428
         msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
         msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
         msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.8428
         msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
         msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
         msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.8428
         msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
         PatchMatch.dll   PatchMatch 2013/10/29-11:47:16   79.542390   79.542390
         pdfsettings.dll   Adobe PDFSettings   1.04
         Photoshop.dll   Adobe Photoshop CC   CC
         Plugin.dll   Adobe Photoshop CC   CC
         PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   4.2.0.36
         PSArt.dll   Adobe Photoshop CC   CC
         PSViews.dll   Adobe Photoshop CC   CC
         SCCore.dll   ScCore 2013/10/30-13:12:12   79.546835   79.546835
         ScriptUIFlex.dll   ScriptUIFlex 2013/10/30-13:12:12   79.546835   79.546835
         svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
         tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
         updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
         WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
      Optional and third party plug-ins: NONE
      Plug-ins that failed to load: NONE
      Flash: NONE
      Installed TWAIN devices: NONE
