1 Reply Latest reply on Jun 4, 2014 3:10 AM by Mylenium
    Slow response of text command
    arjun2 Level 1
      I'm using photoshop cs6 - 64 bit. Whenever I choose the text command, photoshop takes like 15 seconds to get that command active. This was a problem in CS5 version too. What is a way to speed things up? This happens regardless of the filesize. I also have ATI Sunpro 8570 graphics 2gb.
        • 1. Re: Slow response of text command
          Well, you could simply have a gigazillion fonts on your system that mess with the text engine. in that case some serious weeding out of fonts that you never use would help immensely. Otherwise you can always turn off hardware acceleration in the preferences, assuming the issue is related to that...
          Mylenium
