3 Replies Latest reply on Jun 5, 2014 10:32 AM by John Mensinger
    How to list all documents that has linked a image file?
    snowblood13x
      Hi everyone,
      I'd like to know if there's a way to find all linked file to a file: i have a logo image that a lot of inDesign files have linked to it and i'd like to find all those inDesign files.
      I know that Bridge CS6 can list all linked files of a .indd file but i'd like the opposite
      Regards,
      Snowblood13x
        • 1. Re: How to list all documents that has linked a image file?
          Doc Maik Level 4
          Not possible. Indesign does not store extra information about linked files outside of itself or documents.
          • 2. Re: How to list all documents that has linked a image file?
            You might be able to do it via scripting. If you have to search an entire volume it would be impractical, but something like this AppleScript would open all of the ID files inside of a chosen folder and its sub folders. Once the ID file is open it could check for a specific link and if it exists leave the file open otherwise close:
            global mylinkname
            --change YourLinkNameHere to the logo link's name
            set mylinkname to "YourLinkNameHere"
            tell application "Finder"
                activate
                set the thisFolder to (choose folder with prompt "Choose a folder. The extension of all files inside will be hidden.")
                my ProcessFolder(thisFolder)
                tell application "Adobe InDesign CS6"
                    activate
                    display dialog "Done"
                end tell
            end tell
            on ProcessFolder(thisFolder)
                set theseItems to list folder thisFolder without invisibles
                repeat with i from 1 to count of theseItems
                    set thisItem to alias ((thisFolder as text) & (item i of theseItems))
                    set the iteminfo to info for thisItem
                    if folder of the iteminfo is true then
                        ProcessFolder(thisItem)
                    else
                        ProcessItem(thisItem)
                    end if
                end repeat
            end ProcessFolder
            on ProcessItem(thisalias)
                    if creator type of file thisalias is "InDn" and kind of file thisalias is not "InCopy® Lock File" then
                            activate
                            --set user interaction level of script preferences to never interact
                            open thisalias
                            set llist to name of every link of active document
                            if mylinkname is not in llist then
                                tell active document
                                    close
                                end tell
                            end if
                            --set user interaction level of script preferences to interact with all
                        end tell
                    end if
                end tell
            end ProcessItem
            • 3. Re: How to list all documents that has linked a image file?
              John Mensinger Adobe Community Professional & MVP
              If you're running Windows, (or perhaps your files are on a network which includes one or more Windows machines), find and install a search utility named Agent Ransack. It's the free "light" version of a more sophisticated product, but it will find the linked file's name referenced in the "code" of InDesign files.
              For example, a search for *.indd
              ...with linkedfile.ai entered in the "Containing Text" field
              ...will hit all the InDesign files in which linkedfile.ai has been Placed.
              It does exactly what you're asking.
