6 Replies Latest reply on Jun 5, 2014 8:12 AM by A.T. Romano
    Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
    marcos_sp23
      Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account. Tried running in admin mode and crashes.
        • 1. Re: Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
          From the Premiere Elements Information FAQ http://forums.adobe.com/thread/1042180
          •What version of Premiere Elements? Include the minor version number (e.g., Premiere Elements 12 with the 12.0.1 update).
          •What operating system? This should include specific minor version numbers, like "Mac OSX v10.6.8"---not just "Mac"
          •Has this ever worked before?  If so, do you recall any changes you made to Premiere Elements, such as adding Plug-ins, brushes, etc.?  Did you make any changes to your system, such as updating hardware, printers or drivers; or installing/uninstalling any programs?
          •Are you using an account with Administrator Privileges?
          Run as Administrator http://forums.adobe.com/thread/969395 (Encore + "All" Premiere)
          •Have you installed any recent program or OS updates? (If not, you should. They fix a lot of problems.)
          •What kind(s) of image file(s)? When talking about camera raw files, include the model of camera.
          •If you are getting error message(s), what is the full text of the error message(s)?
          •What were you doing when the problem occurred?
          •What other software are you running?
          •Tell us about your computer hardware. How much RAM is installed?  How much free space is on your system (C:) drive?
          And some other questions...
          •What are you editing, and does your video have a red line over it BEFORE you do any work?
          •Which version of Quicktime do you have installed?
          What is your exact brand/model graphics adapter (ATI or nVidia or ???)
          What is your exact graphics adapter driver version?
          Have you gone to the vendor web site to check for a newer driver?
          For Windows, do NOT rely on Windows Update to have current driver information
          -you need to go direct to the vendor web site and check updates for yourself
          ATI Driver Autodetect http://support.amd.com/en-us/download/auto-detect-tool
          nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
          Do you have dual graphics adapters?
          Go to the Windows Control Panel and select Hardware and Sound and then select Device Manager... In Device manager you click the + sign to the left of Display Adapters... and see if 2 are listed
          IF YES, read below
          -http://helpx.adobe.com/premiere-pro/kb/error---preludevideo-play-modules.html
          -http://forums.adobe.com/thread/1001579
          -Use BIOS http://forums.adobe.com/thread/1019004?tstart=0
          -link to why http://forums.adobe.com/message/4685328
          -http://www.anandtech.com/show/4839/mobile-gpu-faceoff-amd-dynamic-switchable-graphics-vs-n vidia-optimus-technology/2
          • 2. Re: Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
            marcos_sp23 Level 1
            Here is my reply:
            Windows 8.1.
            Worked in windows 8. No plug-ins added, etc.
            Yes
            Crashes after loading
            All up to date
            Please log-in with an administrator account to use Premiere Elements
            None
            4gb ram. 30gb free space on internal SSD drive.
            Latest
            Radeon HD 3400
            8.970.100.0
            Yes
            P.S. Premiere Pro works on my system
            • 3. Re: Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
              nealeh Level 5
              Right-click the shortcut and select 'Run As Administrator'. Does that work?
              Do you mean you used an account with Administrator privileges or did you log in as the actual 'Administrator'?
              Did the crash produce an error message?
              Is there any indication in the Event Viewer concerning the crash?
              Cheers,
              Neale
              If this post or another user's post resolves the original issue, please mark the posts as correct accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
              • 4. Re: Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
                A.T. Romano Level 7
                marcos_sp23
                I think that you have already answered the following questions more than once, but I will repeat them one more time before I take another troubleshooting direction.
                (1) In Windows 8.1 64 bit, are you confirming that you went to Control Panel/User Accounts and found the User Account that you are using and it displayed a thumbnail with your User Name underneath which was the word Administrator?
                (2) In Windows 8.1 64 bit, are you confirming that you have applied Run As Administrator to the desktop icon of Premiere Elements 12 and or one or both of its .exe files or the installation setup.exe file?
                (3) At any time did you attempt to create a new User Account with Administrative Privileges and work from that?
                Assuming that the answers to the above are all Yes, then I would like to ask the following:
                (1) Have you installed Premiere Elements 12 to the default location?
                (2) Is the SSD drive your C drive and is 30 GB the only free hard drive space that you have on that computer?
                (3) And, is Premiere Elements 12 installed on the SSD C drive?
                Thanks for the follow ups. We will be watching for further details that might help us to help you.
                Thanks.
                ATR
                • 5. Re: Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
                  marcos_sp23 Level 1
                  1. Yes
                  2. Yes
                  3. Yes
                  Yes
                  Yes. OS and programs are installed on SSD. All other data on 2 external 1tb drives
                  Yes
                  Thanks.
                  MP
                  • 6. Re: Premiere elements won't work on windows 8.1. Says: Please log-in with an admin account.
                    A.T. Romano Level 7
                    MP
                    Thanks for the follow up with the very helpful troubleshooting information.
                    Unless you find some information in the Computer/Manage/Event Viewer/Windows Logs/Application that points to an explanation of this "Log-in with admin account" message, I am suggesting the following.
                    Contact Adobe via its Adobe Chat to discuss the topic "Downloading, Installing, and Setting Up". We are not Adobe here. Just user to user. Adobe has the means to offer remote control troubleshooting if it comes to that. If you want to follow this suggestion, click on the following link. And, when it opens, click on the statement "Still Need Help? Contact us." to bring up the Adobe Chat for the discussion of the topic of "Downloading, installing, and Setting Up:.
                    Contact Customer Care
                    Your contact with Adobe Chat does not prohibit you continuing your discussion of your issue in this thread if necessary.
                    We will be looking forward to further developments.
                    Best wishes
                    ATR
