3 Replies Latest reply on Jun 5, 2014 8:35 AM by C_Barnes
    Help! Fix my javascript to save a bmp with suffix in the same folder as the previous save.
    C_Barnes Level 1
      Here's my current javascript:
      #target photoshop
      // sets document preferences to inches
      app.preferences.rulerUnits = Units.INCHES
      // these are our values for the END RESULT width and height (in inches) of our image
      var fWidth = 11.73;
      var fHeight = 5.97;
      var CurrentDLPFile=app.activeDocument
      var CurrentDLPFileName= CurrentDLPFile.name
      var CurrentDLPFilePath="~/Desktop/fetch"
      var f = File.saveDialog('Save Where?','');
      // in case we double clicked the file
      app.bringToFront();
      // resizes the canvas to 11.73 x 5.97 inches
      CurrentDLPFile.resizeCanvas(UnitValue(fWidth,"in"),UnitValue(fHeight,"in"));
      // flattens all layers
      CurrentDLPFile.flatten();
      // saves as photoshop file
      if (f!=null) CurrentDLPFile.saveAs(f,undefined);
      // splits channels
      CurrentDLPFile.splitChannels();
      // converts active K seperation to bitmap form
      var bitsaveoptions = new BitmapConversionOptions()
      bitsaveoptions.method = BitmapConversionType.HALFTONESCREEN
      bitsaveoptions.angle = 45
      bitsaveoptions.frequency = 55
      bitsaveoptions.resolution = 300
      bitsaveoptions.shape = BitmapHalfToneType.ROUND
      app.activeDocument.changeMode(ChangeMode.BITMAP,bitsaveoptions);
      // THIS IS WHERE I'M HAVING ISSUES- I want to save the file (which at this point is a bmp), with a suffix of 1 in the same folder; and then close the file.
      var doc = app.activeDocument;
      var docName = doc.name;
      docName = docName.match(/(.*)(\.[^\.]+)/) ? docName = docName.match(/(.*)(\.[^\.]+)/):docName = [docName, docName];
      var suffix = '_1';
      var saveName = new File(decodeURI(doc.path)+'/'+docName[1]+suffix+'.bmp');
      function saveFile(app.activeDocument, saveName);
        • 1. Re: Help! Fix my javascript to save a bmp with suffix in the same folder as the previous save.
          pixxxel schubser MVP & Adobe Community Professional
          Hi c_barnes,
          Try this to get the saveName with path for your saveFile:
          var saveFile = File(File(doc.path)+"/"+doc.name.replace (/\.bmp$/,'_1.bmp'));
          alert(saveFile);
          Is this ok for you?
          • 2. Re: Help! Fix my javascript to save a bmp with suffix in the same folder as the previous save.
            C_Barnes Level 1
            Hi pixxel,
            ExtendScript still won't run my code:
            // saves K seperation to bitmap form
            saveBMP = new BMPSaveOptions();
            saveBMP.alphaChannels = false;
            saveBMP.depth = BMPDepthType.ONE;
            saveBMP.flipRowOrder = false;
            saveBMP.rleCompression = false;
            saveBMP.osType = OperatingSystem.WINDOWS;
            var doc = activeDocument;
            activeDocument.saveAs(saveFile, saveBMP, true, Extension.LOWERCASE);
            activeDocument.close( SaveOptions.DONOTSAVECHANGES );
            activeDocument.close()
            ^the bolded line above is where it runs into issues... any ideas? Thanks for your help!
            • 3. Re: Help! Fix my javascript to save a bmp with suffix in the same folder as the previous save.
              C_Barnes Level 1
              I figured it out, here's for anyone else who is struggling with a similar problem:
              // saves active doc as photoshop file
              //renames active document to whatever was saved
              var CurrentDLPFile = app.activeDocument.name
              //assigns the location of the saved psd
              var psdPath = activeDocument.path
              var Name = doc.name.replace(/\.[^\.]+$/, '');
              var Suffix = "1";
              var saveFile = File(psdPath + "/" + Name + Suffix + ".bmp");
