4 Replies Latest reply: Jun 4, 2014 1:37 PM by ramseycdavid RSS
    Displays code within index.cfm from a web browser
    ramseycdavid Community Member
      Installed CF11 on MAMP Pro 3.0.5 on OSX Mavericks. CF server is started as well as Apache and MySQL. When I navigate my desired CF virtual host, It only displays the code within index.cfm in the web browser. Also, when I navigate to localhost/CFIDE/Administrator/index.cfm, it tries to download the file. Any suggestions would be appreciated!
        • 1. Re: Displays code within index.cfm from a web browser
          Also PHP works perfect, but for whatever reason CF connector is messed up or something along those lines..
          • 2. Re: Displays code within index.cfm from a web browser
            Anit Kumar Panda Employee Hosts
            Can you try deleting the connector and re configuring it?
            Regards,
            Anit Kumar
            • 3. Re: Displays code within index.cfm from a web browser
              I have tried uninstalling CF11 completely and performing a clean install, with the same result as described above. There were workarounds for earlier versions of CF10, then update 13 supposedly fixed the issue with OSX 10.9. So, I would think default installation would do the trick in CF11 on OSX 10.9. Any tips on manually configuring it?
              • 4. Re: Displays code within index.cfm from a web browser
                Running the ColdFusion 11 connector wizard
                Configuring the web server connector (Launched on the first run of the ColdFusion server start script)
                Running /Users/david_ramsey/Library/Application Support/appsolute/MAMP PRO connector wizard...
                There was an error while running the connector wizard
                Connector installation was not successful
                If the connector has already been configured, rename the script cfusion/bin/cf-connectors.sh to prevent the connector from configuring again.
                Configuring ColdFusion 11 to start on system init.
                Creating the ColdFusion 11 start script /Library/StartupItems/ColdFusion11/ColdFusion11
                mkdir: /Library/StartupItems/ColdFusion11: File exists
                Install complete
                Start ColdFusion as "./coldfusion start" to run ColdFusion as non-root user.
