6 Replies Latest reply on May 7, 2007 5:19 PM by pajaroplus
    WOW AS3 is so much Faster
    Rothrock Level 5
      We've heard about it, but nobody has posted hard numbers for specific things.
      I'm doing a large amount of matrix math – multiplying two large matrices together. We are talking about approximately 4,718,592 additions and multiplications.
      Under AS2 my class takes about 79 to 80 seconds to calculate the answer. Under AS3 the same class takes about 10 to 11 seconds. I know that is still quite awhile, but an amazing performance boost. Dontchathinkso? This really is going to make an amazing difference in the things we can do with Flash.
      Now if only the AS3 documentation was any good. :)
        • 1. Re: WOW AS3 is so much Faster
          pajaroplus Level 1
          thanks for taking your time :) I appreciate having real numbers.
          • 2. Re: WOW AS3 is so much Faster
            tanenbaumm Level 1
            This is certainly the single biggest plus I can see in Flash CS3 right now (and the only reason I would currently recommend to a client for publishing to FP9).
            • 3. Re: WOW AS3 is so much Faster
              pajaroplus Level 1
              it has more good features.
              - much powerful (computespectrum, loader, ...)
              - much simpler and better structured (not easier if you are not used to code in standard programming languages like C or java)
              - it gives you a lot more of compiling/runtime errors (this is really good, since it prevents you from making mistakes). When you publish your movie it is much more robust and consistent than with AS2.
              • 4. Re: WOW AS3 is so much Faster
                Rothrock Level 5
                It does have some good new features and the speed improvement is great. But after that we differ.
                It may be better structured, but it is not simpler! There are so many classes and so many of them rely on multiple, multiple levels of inheritance. And simple things like the name of a file to load is now a URLRequest and so on add levels of complexity that are not really necessary for small projects.
                The documentation is lousy. In previous versions every (or nearly every) constructor, method, property, and event had a code example. The lack of the same for AS3, is not helpful for folks who are quite familiar with AS2 (that would be me!) and trying to switch over to AS3.
                As you know I believe the lack of any syntax checking for AS3 is also a big minus. It is really annoying to have to compile a swf to find simple typos and other errors that should be found by a syntax check.
                If the goal is to encourage structure and planning in the code, there are many things that don't make it easy for those who are new to AS3.
                • 5. Re: WOW AS3 is so much Faster
                  Cain23
                  I do agree
                  I began using Flash mx 2004 for school projects and it took me just one day to understand it and began doing my work. There was plenty of documentation and tutorials.
                  But with this AS3 i have been stuck with a button for almost 2 days and i cant find info. And the one i have found its really advanced for me (i'm no programmer im in highschool XD)
                  Where is a place with proper documentation about working with AS3?
                  • 6. Re: WOW AS3 is so much Faster
                    pajaroplus Level 1
                    i think that the switch from as2 to as3 needs big time, as it needs to learn as2 when you never used flash. I started one year ago with as3 and i got really pissed, but when i came back to as2 i found that i was coding following the as3 way of thinking, because it was much more effective: my coding had almost no mistakes once i had the initial release of my application finished.
                    Our degree of abstraction has a limit. Classes separate every single part of the program, so you can improve at maximum each part.
                    And yes, there are things that are annoying. In this cases I like to think that the annoying things are there for any of the reasons (speed, flexibility, error avoiding), So i considerer it as the tip.
                    You can always create your custom classes to simplify your day to day. In AS3 you know that you won't have much trouble.
