1. Re: AE is not possible to run on a macbook pro
Rick Gerard Jun 4, 2014 9:16 PM (in response to Luccas Sampaio)Did you install a cuda driver? If so remove it.
2. Re: AE is not possible to run on a macbook pro
Luccas Sampaio Jun 4, 2014 9:32 PM (in response to Rick Gerard)I think my GPU is not compatible with CUDA.
AE is not possible to run the other way?
3. Re: AE is not possible to run on a macbook pro
Rick Gerard Jun 4, 2014 11:05 PM (in response to Luccas Sampaio)If you installed the cuda driver on a system that does not have a Nvidia card AE will not run. AE should run just fine on your system. It runs on my iMac and on my Mac Mini, and my daughters MacBookPro - just like yours, and on my MacBook Pro Retina. Only the MBP retina has the cuda driver installed.
4. Re: AE is not possible to run on a macbook pro
Szalam Jun 5, 2014 6:38 AM (in response to Luccas Sampaio)As Rick says, you need to make sure CUDA isn't installed. People with this error popped up on these forums all the time when they would accidentally install a CUDA driver (migrating systems/upgrading, etc.)
5. Re: AE is not possible to run on a macbook pro
Luccas Sampaio Jun 5, 2014 12:17 PM (in response to Luccas Sampaio)Thanks for the help.
Actually sometime installed cuda driver by mistake.
Excludes CUDA.framework file and am now able to run AE perfectly.
thank you friends
6. Re: AE is not possible to run on a macbook pro
Szalam Jun 5, 2014 12:21 PM (in response to Luccas Sampaio)No problem! Glad we could help.
Don't forget to mark the correct and helpful answers so that future visitors to the forum know that this question has been answered.
7. Re: AE is not possible to run on a macbook pro
Kevin-MonahanJun 5, 2014 1:09 PM (in response to Luccas Sampaio)
Hi Luccas,
Certain programs, like BlackMagic Resolve install a CUDA driver no matter the platform. If you have installed that program, that may explain how you got CUDA.
Kevin
8. Re: AE is not possible to run on a macbook pro
Luccas Sampaio Jun 5, 2014 1:26 PM (in response to Kevin-Monahan)Hello
It was just that, installed Resolves recently.
But now I can already run After Effects without problems.
Thank you.
