0 Replies Latest reply on Jun 5, 2014 4:18 AM by Thomcaptcha
    How to export After Effects Animation for Broadcast in MXF
    Thomcaptcha
      Hello!
      Big fan of the site, and I hope you'll excuse the newbie question.
      I'm currently looking to compress 4 x short 15second trailers for an Indian TV station which have been rendered in after effects. They've requested the following specs, and I'm hitting a few creative walls. The Aspect Ratio and fps I’m absolutely fine with..but I’m a little lost in terms of the rendering container and audio spec.
      As I mentioned I’ve got After Effect, Compressor but I also have Final Cut Pro too. If any one can offer any assistance whatsoever I’d be hugely grateful!
      TVC High Definition HD File Master
      Containers - MXF for XD CAM HD422
      GOP - Long GOP
      Bit Rate type  - CBR
      Video Codec - XD CAM HD 422
      Video bit rate - 50mb/s
      Width -1920
      Height - 1080
      Frames per second -(i) 50 or (p) 25
      Aspect Radio  - 16:9 (Full frame only)
      Audio Codec - PCM & Dolby E
      Bits Per Sample - Dolby E always 20
      # of Audio Channels - 4 tracks as per 1.2
      Audio sample rate - 48Khz
      Audio Track:
      Audio Track 1 - Mono Mix
      Audio Track 2 - Mono Mix
      Audio Track 3 - Dolby E Mix
      Audio Track 4 - Dolby E Mix
      and second video
      TVC High Definition SD File Master
      Containers - MXF OP1A
      GOP - I Frames
      Bit Rate type  - CB
      Video Codec - IMX
      Width - 720
      Height - 576
      Frames per second - 25
      Aspect Radio  - 4:3
      Audio Codec - PCM uncompressed
      Bits Per Sample - 24bit
      Audio Track:
      Audio Track 3 - Mono Mix
      Audio Track 4 - Mono Mix
