This content has been marked as final.
Show 6 replies
1. Re: Can't select "stroke path" in a path I created through "Make Work Path" in CS6
Silkrooster Jun 5, 2014 9:13 PM (in response to Jenn_leo)Stroke path will not be available to you until you literally select the path in the document.
3. Re: Can't select "stroke path" in a path I created through "Make Work Path" in CS6
Silkrooster Jun 5, 2014 9:57 PM (in response to Jenn_leo)Looks like you don't have the entire path selected. Take a look at the curve you can see the anchor node is hollow, meaning it is not selected. Using the direct selection tool, you can drag across the entire path to select all the nodes.
5. Re: Can't select "stroke path" in a path I created through "Make Work Path" in CS6
csuebele Jun 6, 2014 12:56 PM (in response to Jenn_leo)You need to have the path selected as mentioned, you also have to have a brush or pencil tool active, and I don't see your layers pallet, but you have to have a layer on which you can add pixels: normal layer.
6. Re: Can't select "stroke path" in a path I created through "Make Work Path" in CS6
Jenn_leo Jun 6, 2014 2:15 PM (in response to Jenn_leo)I checked and what was missing was the selection of the layer I was working on, thanks!
