4 Replies Latest reply on Jun 6, 2014 2:40 PM by stealthrs
    Easiest Way to Add Spaces
    stealthrs
      I've been trying to figure this out for about 30 minutes, but I'm not a programmer by any means.... On one page, I have agent_code which is 5 characters all together... On another page, I need to split 2 of the characters in one box and 3 in another.... Because of the content on the page I have to fit the typed data into, I need to add spaces... So if I typed in X1A43 into the agent_code box... I need it to come out as "X 1" and "A 4 3"
      I have a bootleg work around (literally make 5 output boxes and slice the values), but I'm trying to get better at understanding this.
      How would you add spaces in between each character in agent_code_part1 and agent_code_part2?
      // Custom Validate script
      (function () {
           // Do nothing if field is blank
          if (!event.value) {
              getField("agent_code_part1").value = event.value = "";
              getField("agent_code_part2").value = event.value = "";
          // Populate the agent_code_part1 and agent_code_part 2 with the first 2 characters and last 3 characters entered into this field, respectively
          if (event.value.length === 5) {
              getField("agent_code_part1").value = event.value.slice(0,2);
              getField("agent_code_part2").value = event.value.slice(2,5);
        • 1. Re: Easiest Way to Add Spaces
          If this is a validation script, wouldn't you also want to validate that the agent code is 5 characters long?
          // clear agent part fields;
          this.resetForm(["agent_code_part1", "agent_code_part2"])
          // assume valid input;
          event.rc = true;
          // test for a 5 alphanumeric string and spilt the string into 2, 1, 2 pieces;
          if(/^(\w{2})(\w{1})(\w{2})$/.test(event.value)) {
          this.getField("agent_code_part1").value = RegExp.$1
          this.getField("agent_code_part2").value = RegExp.$2 + " " + RegExp.$3;
          } else if(event.value != "") {
          event.rc = false;
          app.alert("Agent code needs to be 5 characters long", 0, 0);
          • 2. Re: Easiest Way to Add Spaces
            stealthrs Level 1
            It is definitely helpful, thanks.
            So... I don't exactly know what you did, but I tried my best to figure it out... To get it to do exactly what I wanted to do (I needed an extra two spaces), I changed the code to this, and it worked like a charm... Thanks!
            event.rc = true;
            if(/^(\w{1})(\w{1})(\w{1})(\w{1})(\w{1})$/.test(event.value))
            this.getField("agent_code_part1").value = RegExp.$1 + " " + RegExp.$2
            this.getField("agent_code_part2").value = RegExp.$3 + " " + RegExp.$4 + " " + RegExp.$5;
            event.rc = false;
            • 3. Re: Easiest Way to Add Spaces
              stealthrs Level 1
              P.S. Is it just me, or did Adobe's forums lose a ton of functionality and become a lot more difficult to navigate and search through archives????
              I can't even edit previous posts now
              :update: Figured out how to edit posts, but this site is a lot more disorganized (functionally speaking)
              • 4. Re: Easiest Way to Add Spaces
                stealthrs Level 1
                GK,
                What if I needed add spacing like before, but only pulling from 1 field that doesn't have a length requirement... The original field with no spaces can be at minimum 1 characters.  Let's say it's called percentage_case1
                The output box (percentage_case1_juv) is what needs the spaces between the characters... So if I typed in 100 into percentage_case1, then percentage_case1_juv would read "1 0 0"
                If I typed in So if I typed in 90 into percentage_case1, then percentage_case1_juv would read "9 0"
