2 Replies Latest reply on Jun 7, 2014 1:51 AM by Mylenium
    how to make a freeze frame sequence
    winniecash
      title pretty much says it
        • 1. Re: how to make a freeze frame sequence
          I don't know what a freeze frame sequence is. Sounds it is a bunch of freeze frames tied together, or it could be a video that plays for a while and then freezes.
          In the first case you might want to try posterize time, which would make a video jump say 10 frames at a time.
          In the second case, you would move the CTI (Current Time Indicator) to the point when you want to freeze the frame and then go to Layer > Time > Freeze Frame.
          If a freeze frame sequence is something else please give us an accurate description or example.
          • 2. Re: how to make a freeze frame sequence
            No, it doesn't. You no speak English. *lol* As Rick said, if you mean something else than just a slideshow thingy based on a couple of stills you need to explain better.
            Mylenium
