4 Replies Latest reply on Jun 10, 2014 6:48 PM by New Guy 40
    JS Help
    New Guy 40
      With this script, I am trying to make the statement... IF FamilyMember=3 then Family1 is not diplayed, else Family1 is displayed.  However the following script does not work
      var FamilyMemeber=this.getField("SelectFamily1")
      if(FamilyMember==3)
      var Family1 = ""
      else
      var Family1 = this.getField("SelectFamily1").value
      this.getField("FirstName1").value
      this.getField
      ("LastName1").value
      "(Born in"
      this.getField
      ("COB1").value
      this.getField
      ("Status1").value
      + " DOB: " +
      this.getField
      ("DOB1").value
      var Family2 = this.getField("SelectFamily2").value
      this.getField("FirstName2").value
      this.getField
      ("LastName2").value
      "(Born in"
      this.getField
      ("COB2").value
      this.getField
      ("Status2").value
      + " DOB: " +
      this.getField
      ("DOB2").value
      event.value = Family1 + Family2;
        • 1. Re: JS Help
          George_Johnson MVP & Adobe Community Professional
          if(FamilyMember==3)
          That first line does not get the value of the field, it sets the FamiliyMemeber variable to a field object. It also looks like there's a typo in the field name (Memeber vs Member). You should also use curly braces ({}) in your if/else blocks. Without them, it is unclear which code belongs within the else clause.
          • 2. Re: JS Help
            New Guy 40 Level 1
            Do you have an example code I can use?
            • 3. Re: JS Help
              If I understand your code correctly, I believe it should be something like this:
              var Family1 = "";
              var FamilyMember =  getField("SelectFamily1").value;
              if (FamilyMember != 3) {
                  Family1 = getField("SelectFamily1").valueAsString + " " +
                            getField("FirstName1").valueAsString + " " +
                            getField("LastName1").valueAsString + " (Born in " +
                            getField("COB1").valueAsString + ". " +
                            getField("Status1").valueAsString + " DOB: " +
                            getField("DOB1").valueAsString + "). ";
              var Family2 = getField("SelectFamily2").valueAsString + " " +
                            getField("FirstName2").valueAsString + " " +
                            getField("LastName2").valueAsString + " (Born in " +
                            getField("COB2").valueAsString + ". " +
                            getField("Status2").valueAsString + " DOB: " +
                            getField("DOB2").valueAsString + "). ";
              // Set this field's value
              • 4. Re: JS Help
                New Guy 40 Level 1
                Thanks for you help, I really appreciate it.
                What my code is attempting to do is......
                if FamilyMember !=3 then the value of Family1 =""
                So would this be correct?
                    var Family1 = "";}
