1. Re: Is anyone else not getting any results from CFBuilder 3 File Search?
PapaMech Jul 2, 2014 1:04 PM (in response to Kibbage.TEESO)The results show up in the search panel. That panel may not be obvious. Is there anything in that panel?
2. Re: Is anyone else not getting any results from CFBuilder 3 File Search?
Kibbage.TEESO Jul 2, 2014 2:23 PM (in response to PapaMech)The panel shows up it just says "zero matches in working set". Any other ideas?
3. Re: Is anyone else not getting any results from CFBuilder 3 File Search?
PapaMech Jul 2, 2014 2:44 PM (in response to Kibbage.TEESO)That sucks. This is what worked for me:
-Selected the project in the navigator
-Clicked on the search menu item and the search dropdown.(same as cntrl-h)
-Entered my search term.
-Put in *.cfc, *.cfm for the file name pattern
-Selected 'Enclosing projects' which is supposed to search the project selected.
-Clicked the search button.
I gave you the initial response above because I didn't notice the search panel the first time I tried it.
4. Re: Is anyone else not getting any results from CFBuilder 3 File Search?
Kibbage.TEESO Jul 2, 2014 3:16 PM (in response to PapaMech)You found it! I had always used "Working set" and one or more selected working sets. That doesn't work nor does selected resource. However "Enclosed Projects" and the much wider scope of "Workspace" do work. Thank you!
