2 Replies Latest reply on Jun 8, 2014 6:32 PM by Rowby
    Can I swap out my old Areca 1880-ix with the newer Areca  ARC-1883
    Rowby Level 1
      Hello everyone.  It's been a while since I've been here.
      I think, but am not sure, that my Areca 1880-ix is dead. I'll be contacting Areca support to see if I can have them help me troubleshoot it.  Like they did a year or so ago.
      In any case I see a new Areca  ARC-1883 added to their line.   Areca Technology Corporation and here Areca Technology Corporation
      And if I can't get the old 1880-ix working, I am wondering what the Abobe forum's thought might be about this new Areca  ARC-1883.
      To summarize, I have one system hard drive, and 4x 1TB hard drives = 4 TB.
      Based on anyone's experience here, does such a swap make sense?
      Looking forward to a discussion here about my choices.
      I do see Bill's post here:  Upgrading HD Capacity Areca
      Thanks all!
      Rowby
        • 1. Re: Can I swap out my old Areca 1880-ix with the newer Areca  ARC-1883
          Bill Gehrke Adobe Community Professional & MVP
          I suspect that you could do that but an ARC 1883 really would be an investment towards a future system upgrade.  I do not remember your system (I did search PPBM5 results unsuccessfully) but did not find your data.  So some of the expensive advantages of the newer board you could not utilize with your older motherboard/disk components. Why don't you check with Areca to see if they have a lower price older option, unless you are considering a major system upgrade in the not to distant future  I just ventured to my junk filled basement and checked on one of my very early builds that has an Areca controller in it but unfortunately it was the preceding generation an ARC-1680 model.
          You might check ebay for a used one or I think the one I just looked at on Amazon appears to be unused.  Maybe Areca has refurbished older models.
          • 2. Re: Can I swap out my old Areca 1880-ix with the newer Areca  ARC-1883
            Rowby Level 1
            Hi Bill
            Checking some of my older forum posts I found that I had encountered this issue before.
            ASUS P6X58D Memory OK (MEMOK!) issue DRAM LED Stays solid red.
            It turned out that my problem was just the motherboard's battery had died.  We're talking about a 99 cent battery!
            I replaced the battery with a new one.
            And the PC booted up just fine.
            (This was after I totally disassembled the computer -- testing the power supply with the "paper clip" method, reconnecting all of my cables.
            By chance, I found that old post.  And, at least for now, all is fine.
            Great to have this forum and pros like you -- and Harm -- and all the others -- as a great place for troubleshooting and expert help!!!
            Rowby
