4 Replies Latest reply on May 8, 2007 5:35 PM by Rothrock
    help "mr can't program for toffee" with his array
    wAyStead Level 1
      hey people,
      i posted this topic a few days back and had a great response but can't seem to make the code
      supplied work...
      my current code is
      var randomMax:Number = 10;
      var randomMin:Number = 1;
      var randomFileNum:Number = Math.floor(Math.random() * randomMax + randomMin);
      trace(randomFileNum); //will display from 1 to 10;
      loadMovieNum(randomFileNum + ".swf", 1);
      THIS WORKS GREAT EXCEPT FOR THE RANDOM REPEATS which i need to
      eliminate
      if someone wouldn't mind scripting the whole code for me (Coz i'm thick)
      with the assumption that the files i want to shuffle are called
      301.swf
      302.swf
      303.swf
      304.swf
      305.swf
      306.swf
      307.swf
      help me obi won kenobi, your my only hope....
      THIS WAS THE POSTED SOLUTION :
      easiest just to make an array of the numbers you need and shuffle it.
      //And ths code to add the shuffle method to the array class
      Array.prototype.shuffle = function() {
      var i:Number;
      this.sort(function(a,b) { i = Math.round((Math.random() * 100) - 50); return i;});
      return this;
      var fileNum_array = [];//declare empty array
      for( var i=randomMin;i<=randomMax;i++)
      fileNum_array.push(i);
      fileNum_array.shuffle();
      then pull the values out of the array incrementally
      loadMovieNum(fileNum_array[0] + ".swf", 1);
      loadMovieNum(fileNum_array[1] + ".swf", 1);
      loadMovieNum(fileNum_array[2] + ".swf", 1);
      etc...
      or use an incrementing variable everytime you need to return a value
      var myIncVar = 0;
      loadMovieNum(fileNum_array[myIncVar++] + ".swf", 1);
      etc...
      Hope that helped, Ade
        • 1. help &quot;mr can't program for toffee&quot; with his array
          pajaroplus Level 1
          i would change the shuffle function. The one provided needs a random number of loops.
          The number of loops for this next one is equal to the array length:
          • 2. Re: help &quot;mr can't program for toffee&quot; with his array
            wAyStead Level 1
            i try this code and it just crashes when i run flash despite no script errors....
            any other suggestions ? or can some one supply the entire script as maybe i'm
            editing it wrong with my existing script...
            the opening of my script beings :
            on (rollOver) {
            gotoAndPlay(2);
            on (releaseOutside, rollOut) {
            gotoAndPlay(11);
            on (release) {
            THIS IS THE NEW CODE REPLACING MY PREVIOUS RANDOMISER AS SUGGESTED
            var tmpArray=this;
            var responseArray=[];
            while (tmpArray.length) {
            var newElement=tmpArray.splice( Math.floor( Math.random()*tmpArray.length ), 1 );
            responseArray.push( newElement );
            return responseArray;
            WHAT AM I DOING WRONG ?
            • 3. Re: help &quot;mr can't program for toffee&quot; with his array
              dr_ross Level 1
              well the code you've got there will generate an array, then randomise it fine. and you can prove that by simply tracing out the value of fileNum_array i.e. trace(fileNum_array);
              The problem must be in how you are reading the values out and utilising them in your loading of movies. Look for the error you get traced out at runtime when you try and load in external movies , something like "error file 1.swf is not found" and that'l indicate what values are coming through to your "loadMovieN function.
              Once you've done that and theres nothing obvious, post the section of code where you are calling
              "loadMovieNum(fileNum_array[0] + ".swf", 1);" - that'l probably be the problem
              • 4. Re: help &quot;mr can't program for toffee&quot; with his array
                Rothrock Level 5
                PS: Go back to the original shuffle prototype that I gave you in the other thread. It works just fine as it is!
                Also the slice() will make the shufle take longer. Not really a problem for a small number of items in the array…
