3 Replies Latest reply on May 8, 2007 5:52 AM by cbr985hd
    WEB SERVICE AUTHENTICATION
    Rahul Mainkar Level 1
      Hi All,
      I have a search application which is built in flex and uses SOA.
      I use 3 webservices to access the data from the backend ,which is a R/3 system.
      I have hard coded the WSDL for the webservice in my appplication. Webservice are secured i.e (authentication is needed)
      Now I have hosted this application on a server ( say MAIN SERVER) (which also has the webservices on it) and everything works fine.
      We have a proxy server in place to make this MAIN SERVER available on the internet.
      When I try to use my application from the MAIN SERVER, it works as fine as it can, however as soon as I try to acces it via the proxy server, the webservices do not respond properly and I get a " Security error" and " Unable to load WSDL" error.
      I dont know what can be a work around for this issue. Also both the servers are in the same domain.
      Thanks in advance for any help in this regard.
