• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Can I use a php script in muse?
Participant ,
Jun 09, 2014 Jun 09, 2014
I want to create a membership site using Adobe Muse, so I need to know if I can use .php script for this? When I open up the page properties there doesn't seem to be a way to convert a page from .html to .php .
Views
13.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Dec 04, 2016 Dec 04, 2016
Hello,
Yes you can use php with adobe muse by using phpmuse that converts muse sites to php check: http://www.phpmuse.com
Votes
Translate
Translate
Adobe Employee ,
Jun 10, 2014 Jun 10, 2014
You can't change the Muse pages into .php pages. It creates the pages in .html format only.
Regards,
Aish
Votes
Translate
Translate
Report
Report
Participant ,
Aug 05, 2014 Aug 05, 2014
Thanks.
Votes
Translate
Translate
Report
Report
Participant ,
Dec 17, 2016 Dec 17, 2016
I have found that it is possible to run .php with Muse, it's working well on one of my sites through the server.
Votes
Translate
Translate
Report
Report
Aug 29, 2014 Aug 29, 2014
If you have access to your server, and can restart it, and you know whether PHP is running as a module or cgi, and so on, the best solution is to include a ".htaccess" file in your root document directory to tell the server to parse HTML files (process the PHP code inside). For example:
DirectoryIndex index.html index.htm index.shtml index.php
RemoveHandler .html .htm
AddType application/x-httpd-php .php .html .htm
Search for something like "parse php in html files" for more information and various configurations. And remember to restart your server before expecting it to work.
Anyway, once you've done that, you can paste in a PHP include, or script or entire page or whatever, just as you would the code for a Google map, Facebook feed, etc.
Votes
Translate
Translate
Report
Report
Hello,
Votes
Translate
Translate
Report
Report
New Here ,
Oct 21, 2017 Oct 21, 2017
I set up PHPMuse, and quickly discovered (on a scratch/testing site) that it made an image invisible (the only one on site) and also disabled any breakpoints (when i hit a breakpoint, everything disappeared).  Back in normal HTML version, everything works great.  I looked at the PHPMuse.php script, it seems harmless enough, it's just renaming the .html to .php and replacing your [[php script call]] with the actual php script tag.  Is there a chance the adobe muse scripts are relying on some things ending in .html to function normally?
Votes
Translate
Translate
Report
Report
New Here ,
Jan 13, 2018 Jan 13, 2018
LATEST
the site is down 404
Votes
Translate
Translate
Report
Report
