8 Replies Latest reply on Jun 24, 2014 10:34 AM by harrylr_2
    Why is my flash update freezing? (Screenshot)
    josharnet
      I am trying to install the latest flash player update but it just freezes when I run the installer.
      Not sure if this is downloading the update per say, but I left it running for over an hour and nothing happened, just a spinning pinwheel.
      I am on a Mac, OSX 10.9.3 Mavericks, and trying to install the latest flash player update. I added a screenshot below...
      Also where should I have posted this?
      My thread in the apple support forum: Why is my flash update freezing?...: Apple Support Communities
        • 2. Re: Why is my flash update freezing? (Screenshot)
          pwillener Level 8
          [topic moved to the Installing Flash Player forum]
          • 3. Re: Why is my flash update freezing? (Screenshot)
            Alfredar
            Thanks a lot. I had the same problem as the OP. Your solution worked.
            Alfred
            • 4. Re: Why is my flash update freezing? (Screenshot)
              Desert Dweller
              There must be a problem with the latest Flash Installer, because I haven't had issues with the installers before this version. I'm getting the spinning beach ball after authorizing the installation on my MBP.
              I'm seeing these log files in Console:
              Install Adobe Flash Player_2014-06-11-154629_<my computer name>.hang
              Command:         Install Adobe Flash Player
              Path:            /Users/USER/Desktop/Install Adobe Flash Player.app/Contents/MacOS/Install Adobe Flash Player
              Process:         Install Adobe Flash Player [8598]
                16 ??? (Install Adobe Flash Player + 4117) [0x2015]
                  16 ??? (Install Adobe Flash Player + 5283) [0x24a3]
                    16 ??? (Install Adobe Flash Player + 227337) [0x38809]
                                                  16 ??? (Install Adobe Flash Player + 211532) [0x34a4c]
                                                    16 ??? (Install Adobe Flash Player + 23696) [0x6c90]
                                                      16 ??? (Install Adobe Flash Player + 82988) [0x1542c]
                      16 ??? (Install Adobe Flash Player + 506316) [0x7c9cc]
                        16 ??? (Install Adobe Flash Player + 448490) [0x6e7ea]
                          16 ??? (Install Adobe Flash Player + 445751) [0x6dd37]
                            16 ??? (Install Adobe Flash Player + 423904) [0x687e0]
                            0x1000 -            0xa2ff7  com.solidstatenetworks.host 2.0.2.7 (2.0.2.7) <EC21308F-D578-3FFE-B9A2-7227806047BE> /Users/USER/Desktop/Install Adobe Flash Player.app/Contents/MacOS/Install Adobe Flash Player
              and this:
              6/11/14 15:23:38.711 SIMBL Agent[535]: Install Adobe Flash Player started
              6/11/14 15:23:38.712 SIMBL Agent[2416]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
              6/11/14 15:23:38.714 SIMBL Agent[535]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
              6/11/14 15:23:38.733 Install Adobe Flash Player[5808]: 'ascr'/'gdut' event received from process (pid=2416 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
              6/11/14 15:23:38.733 Install Adobe Flash Player[5808]: 'ascr'/'gdut' event blocked because this process doesn't export scripting additions
              6/11/14 15:23:38.734 Install Adobe Flash Player[5808]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x56056, pid=2416, because it is not entitled to send an AppleEvent to this process.
              6/11/14 15:23:38.734 Install Adobe Flash Player[5808]: 'ascr'/'gdut' event received from process (pid=535 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
              6/11/14 15:23:38.734 Install Adobe Flash Player[5808]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x28028, pid=535, because it is not entitled to send an AppleEvent to this process.
              6/11/14 15:27:36.000 kernel[0]: process Install Adobe Fl[5808] caught causing excessive wakeups. Observed wakeups rate (per sec): 189; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 45014
              6/11/14 15:27:37.729 spindump[6341]: Saved wakeups_resource.spin report for Install Adobe Flash Player version 2.0.2.7 (2.0.2.7) to /Library/Logs/DiagnosticReports/Install Adobe Flash Player_2014-06-11-152737_<my computer name>.wakeups_resource.spin
              6/11/14 15:40:49.548 SIMBL Agent[535]: Install Adobe Flash Player started
              6/11/14 15:40:49.549 SIMBL Agent[2416]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
              6/11/14 15:40:49.550 SIMBL Agent[535]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
              6/11/14 15:40:49.569 Install Adobe Flash Player[8146]: 'ascr'/'gdut' event received from process (pid=2416 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
              6/11/14 15:40:49.569 Install Adobe Flash Player[8146]: 'ascr'/'gdut' event blocked because this process doesn't export scripting additions
              6/11/14 15:40:49.569 Install Adobe Flash Player[8146]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x56056, pid=2416, because it is not entitled to send an AppleEvent to this process.
              6/11/14 15:40:49.570 Install Adobe Flash Player[8146]: 'ascr'/'gdut' event received from process (pid=535 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
              6/11/14 15:40:49.570 Install Adobe Flash Player[8146]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x28028, pid=535, because it is not entitled to send an AppleEvent to this process.
              6/11/14 15:43:58.725 SIMBL Agent[535]: Install Adobe Flash Player started
              6/11/14 15:43:58.727 SIMBL Agent[2416]: warning: failed to get scripting definition from /Users/<my user account>/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
              6/11/14 15:43:58.727 SIMBL Agent[535]: warning: failed to get scripting definition from /Users/<my user account>/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
              6/11/14 15:43:58.755 Install Adobe Flash Player[8598]: 'ascr'/'gdut' event received from process (pid=2416 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
              6/11/14 15:43:58.755 Install Adobe Flash Player[8598]: 'ascr'/'gdut' event blocked because this process doesn't export scripting additions
              6/11/14 15:43:58.755 Install Adobe Flash Player[8598]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x56056, pid=2416, because it is not entitled to send an AppleEvent to this process.
              6/11/14 15:43:58.756 Install Adobe Flash Player[8598]: 'ascr'/'gdut' event received from process (pid=535 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
              6/11/14 15:43:58.756 Install Adobe Flash Player[8598]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x28028, pid=535, because it is not entitled to send an AppleEvent to this process.
              6/11/14 15:46:29.826 spindump[8950]: Saved hang report for Install Adobe Flash Player version 2.0.2.7 (2.0.2.7) to /Library/Logs/DiagnosticReports/Install Adobe Flash Player_2014-06-11-154629_<my computer name>.hang
              I'm wondering why SIMBL appears to be involved in this process, unless that message is a red herring. I have EasySIMBL version 1.4 installed.
              • 5. Re: Why is my flash update freezing? (Screenshot)
                Desert Dweller Level 1
                Pat Willener:
                Thanks for that link.—it worked for me. I hope someone in Adobe's Tech Support is monitoring these forums. There is clearly something wrong with the other update installer. I pasted some log info in my other reply about having problems with the installer.
                • 6. Re: Why is my flash update freezing? (Screenshot)
                  djkinkle
                  I had the same issues... I posted to twitter, under the handle @djkinkle , about it with screen shots.
                  Also, I'm going to post the link to the download located in this forum to twitter.
                  • 7. Re: Why is my flash update freezing? (Screenshot)
                    josharnet Level 1
                    Thanks a lot that solved it!
                    • 8. Re: Why is my flash update freezing? (Screenshot)
                      harrylr_2
                      Pat Willener -
                      Thank you, that direct link worked for me as well (Mavericks 10.9.3), I appreciate your help.
                      Harry
