In Frame10, I am converting my unstructured documents to structured. I found Russ's sample conversion and EDD files (Resources/downloads - West Street Consulting), and I'm customizing those with great success so far. (Thanks, Russ!)
When I convert and apply my EDD, an extra paragraph is inserted to contain my anchored frame and marker. I don't want the extra paragraph. I have tried with and without the (promote) qualifier, both add the extra paragraph, but the promote sticks it in a Body paragraph with no formatting.
In Russ's original EDD, there was a GraphicSpacer inserted for every Figure. I removed this, as I thought it was adding the extra paragraph. Alas, still getting the paragrapg insert,
Here's my EDD spec (which of course is copied from Russ's):
Element (Container): Figure
General Rule: Graphic+ (Caption |CaptionNumbered)?
Automatic Insertions
Automatically insert child: Graphic
Element (Graphic): Graphic
Initial graphic element format
1. In all contexts.
Insert imported graphic file.
And this is how it looks
And this is how it should look
Thank you!
--Amy
