2 Replies Latest reply on Jun 12, 2014 11:14 PM by ict-centraal
    upgrade to coldfusion 11
    ict-centraal Level 1
      I'm working for a few years on a school.
      When I started working they were using Coldfusion 9 Enterprise.
      I would like to upgrade to Coldfusion 11 Standard.
      Looking at Buying guide | Adobe ColdFusion I can' t see a reason to buy the Enterprise for our small website.
      Or is there a good reason?
      Is it possible to upgrade from Coldfusion 9 Enterprise to a Coldfusion 11 Standard and migrate it from one server to another?
        • 1. Re: upgrade to coldfusion 11
          Carl Von Stetten Adobe Community Professional & MVP
          If you only run one website, and aren't doing any clustering of ColdFusion and using any of the Enterprise-only features (you'll have to look at one of the feature matrices to see what is Enterprise-only), then you should be fine with Standard.  There are a couple of ways to migrate your settings.  If you create a CAR file from CF9 Administrator, you should be able to import it into CF11.  Just make sure you install CF11 first as a trial (no serial number) and in standalone mode.  Then import the CAR, then once all the settings have been migrated correctly, put in the Standard serial number.
          -Carl V.
          • 2. Re: upgrade to coldfusion 11
            First I will test the Coldfusion 11 in my testenvironment, ESXi.
            Create a snapshot and the upgrade to version 11 Standard edition.
            And the see if everything on the website is still working.
            Hoping everything works with the standard edition: the price difference between standard and enterprise is rather big....
