2 Replies Latest reply on Jun 13, 2014 10:33 AM by k3n12ock
    ObjectModel.dll causing InDesign CC to crash.
    k3n12ock Level 1
      We recently reinstalled Adobe Creative Cloud InDesign on a users' computer. Every time we open a project directly, it crashes; however if you open InDesign and then open the project, it works fine. Not sure as to why it's happening. Photoshop and other programs have no issues. I copied the errors down and will post here. Maybe someone can help. I did notice something about "ObjectModel.dll" seeing that it is the issue.
      The computer is running Windows 7 Pro x64.
      Adobe Creative Cloud w/ all installed software up to date.
      The following is the info I that was given. Hopefully someone can help.
      Problem signature:
        Problem Event Name:    APPCRASH
        Application Name:    InDesign.exe
        Application Version:    9.0.0.244
        Application Timestamp:    5176f4c7
        Fault Module Name:    ObjectModel.dll
        Fault Module Version:    9.0.0.244
        Fault Module Timestamp:    5176f4b9
        Exception Code:    c0000005
        Exception Offset:    00000000000261c0
        OS Version:    6.1.7601.2.1.0.256.4
        Locale ID:    1033
        Additional Information 1:    9529
        Additional Information 2:    9529754cc72c58f900e33c4f1855fb96
        Additional Information 3:    fe5f
        Additional Information 4:    fe5f55426fc3e5a2feae05a45cff6f40
      Read our privacy statement online:
        http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
      If the online privacy statement is not available, please read our privacy statement offline:
        C:\Windows\system32\en-US\erofflps.txt
      Application: InDesign.exe
      Framework Version: v4.0.30319
      Description: The process was terminated due to an unhandled exception.
      Exception Info: exception code c0000005, exception address 000007FEF00761C0
      Stack:
      - System
        - Provider
         [ Name]  .NET Runtime
        - EventID 1026
         [ Qualifiers]  0
         Level 2
         Task 0
         Keywords 0x80000000000000
        - TimeCreated
         [ SystemTime]  2014-06-10T22:32:12.000000000Z
         EventRecordID 33456
         Channel Application
         Computer Eric3.***.com
         Security
      - EventData
         Application: InDesign.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: exception code c0000005, exception address 000007FEF00761C0 Stack:
      Faulting application name: InDesign.exe, version: 9.0.0.244, time stamp: 0x5176f4c7
      Faulting module name: ObjectModel.dll, version: 9.0.0.244, time stamp: 0x5176f4b9
      Exception code: 0xc0000005
      Fault offset: 0x00000000000261c0
      Faulting process id: 0x15d0
      Faulting application start time: 0x01cf84fbcabba0d8
      Faulting application path: C:\Program Files\Adobe\Adobe InDesign CC (64 bit)\InDesign.exe
      Faulting module path: C:\Program Files\Adobe\Adobe InDesign CC (64 bit)\ObjectModel.dll
      Report Id: 10de3b84-f0ef-11e3-80c7-24be05e10f96
      - System
        - Provider
         [ Name]  Application Error
        - EventID 1000
         [ Qualifiers]  0
         Level 2
         Task 100
        - TimeCreated
         [ SystemTime]  2014-06-10T22:32:13.000000000Z
         EventRecordID 33457
         Channel Application
         Security
      - EventData
         InDesign.exe
         9.0.0.244
         5176f4c7
         ObjectModel.dll
         9.0.0.244
         5176f4b9
         c0000005
         00000000000261c0
         15d0
         01cf84fbcabba0d8
