6 Replies Latest reply on Jun 25, 2014 8:25 AM by LeoTaro
    plugin path in MAC OS
    vincentdoan
      Anyone know how to find the AI plugin path on Mac?
      On Windows, we look in the registry, but how about in MAC?
        • 1. Re: plugin path in MAC OS
          LeoTaro Level 4
          Which process are you trying to get the path from? An installer? A running plugin?
          • 2. Re: plugin path in MAC OS
            vincentdoan Level 1
            Thanks for reply,
            I need to create and installer for the plugin.
            Also, what software do you use to write the installer?
            I am thinking of Qt for that, what do you think?
            Vincent
            • 3. Re: plugin path in MAC OS
              panduvittala
              Installer in MAC is dicey. MAC people are not used to traditional next-next installers, but more of double click dmg, drag drop the app into application folder types. There are few softwares like package maker, etc. Check this out WhiteBox - Packaging  .  Building installer using qt is really a headache.
              For plugin location, you can assume /Applications/Adobe/Adobe Illustrator/Plugins.localized. If you don't find this directory, you can prompt user for install dir.
              For windows use innosetup, beats everything else handsdown.
              • 4. Re: plugin path in MAC OS
                vincentdoan Level 1
                Thanks, I agree, qt is really a headache. I will look at WhiteBox. I guess, assuming the install path at /Application/... is ok, but I thought Adobe would log the path at a known location in a standard file when user install the application.
                • 5. Re: plugin path in MAC OS
                  panduvittala Level 1
                  The way illustrator is installed is by copying the install into application folder from dmg, so there is no question of log. Also mac does not have anything equivalent to registry, so I am not sure if the app paths are logged at all.
                  • 6. Re: plugin path in MAC OS
                    LeoTaro Level 4
                    I know of 2 mac functions for getting application paths.
                    NSWorkspace absolutePathForAppBundleWithIdentifier
                    LSFindApplicationForInfo
                    Note that if there are multiple versions of Illustrator installed, these two functions may return different results.
                    For my plugins I create zxp files that can be installed using the Extension Manager, though there are rumours that Adobe are going to drop the Extension Manager and make developers build their own installers.
