9 Replies Latest reply on Jun 19, 2014 10:35 AM by JJMack
    Need help with openDialog
    sak1364 Level 1
      In the Photoshop script I'm writing, I ask the user to open a file using:
           open(File(openDialog()));
      That works fine. But the user will always be opening an Illustrator (.ai) file.
      Normally that brings up a dialog box called "Import PDF".
      But that dialog doesn't come up with this open command and just uses the default options. I need to set 2 values: 1) uncheck Anti-aliased, and 2) Mode to CMYK.
      I'm new to this and I can't figure out how to set those options. (I don't understand Adobe's Javascript documentation.) Can someone help?
      Thanks!
        • 1. Re: Need help with openDialog
          sak1364 Level 1
          As I look more, I think I need to set the parameters this way
              var OpenAIFile = new PDFOpenOptions
              OpenAIFile.antiAlias = false
              OpenAIFile.mode = OpenDocumentMode.CMYK
              OpenAIFile.resolution = 300
          But what Open command do I use, and how do I insert these parameters?
          • 2. Re: Need help with openDialog
            I think you will need you use openDialog to select the ai file and Scriptlistener code to import the ai file. This seems to work for me though I don't have illustrator I found some .ai file on my machine. CMYK 300DPI ANTIALIAIS hard coded file mad a variable
            var imagePath = "";
            var dir = Folder(imagePath);
            selectAIfile = dir.openDlg("Select .ai File" , "Select:*.ai");
            if ( selectAIfile == null ) {                                   // User canceled
                    alert("Selection Canceled");
            else {
                    importAI(selectAIfile); // Import
            function importAI(file) {
                    //alert(file);
                    // Isolate File Name
                    var Name =  decodeURI(file).replace(/\.[^\.]+$/, '');   // strip the extension off
                    var imagePath = "";
                    while (Name.indexOf("/") != -1 ) {                              // Strip Path
                            imagePath= imagePath + Name.substr(0, Name.indexOf("/") + 1);
                            Name = Name.substr(Name.indexOf("/") + 1 ,);
                    //alert(Name);
                    var idOpn = charIDToTypeID( "Opn " );
                            var desc1 = new ActionDescriptor();
                            var idAs = charIDToTypeID( "As  " );
                                    var desc2 = new ActionDescriptor();
                                    var idNm = charIDToTypeID( "Nm  " );
                                    desc2.putString( idNm, Name );
                                    var idCrop = charIDToTypeID( "Crop" );
                                    var idcropTo = stringIDToTypeID( "cropTo" );
                                    var idboundingBox = stringIDToTypeID( "boundingBox" );
                                    desc2.putEnumerated( idCrop, idcropTo, idboundingBox );
                                    var idRslt = charIDToTypeID( "Rslt" );
                                    var idRsl = charIDToTypeID( "#Rsl" );
                                    desc2.putUnitDouble( idRslt, idRsl, 300.000000 );
                                    var idMd = charIDToTypeID( "Md  " );
                                    var idClrS = charIDToTypeID( "ClrS" );
                                    var idECMY = charIDToTypeID( "ECMY" );
                                    desc2.putEnumerated( idMd, idClrS, idECMY );
                                    var idDpth = charIDToTypeID( "Dpth" );
                                    desc2.putInteger( idDpth, 8 );
                                    var idAntA = charIDToTypeID( "AntA" );
                                    desc2.putBoolean( idAntA, false );
                                    var idWdth = charIDToTypeID( "Wdth" );
                                    var idPxl = charIDToTypeID( "#Pxl" );
                                    desc2.putUnitDouble( idWdth, idPxl, 1943.000000 );
                                    var idHght = charIDToTypeID( "Hght" );
                                    desc2.putUnitDouble( idHght, idPxl, 276.000000 );
                                    var idCnsP = charIDToTypeID( "CnsP" );
                                    desc2.putBoolean( idCnsP, true );
                                    var idsuppressWarnings = stringIDToTypeID( "suppressWarnings" );
                                    desc2.putBoolean( idsuppressWarnings, false );
                                    var idfsel = charIDToTypeID( "fsel" );
                                    var idpdfSelection = stringIDToTypeID( "pdfSelection" );
                                    var idpage = stringIDToTypeID( "page" );
                                    desc2.putEnumerated( idfsel, idpdfSelection, idpage );
                                    var idPgNm = charIDToTypeID( "PgNm" );
                                    desc2.putInteger( idPgNm, 1 );
                            var idPDFG = charIDToTypeID( "PDFG" );
                            desc1.putObject( idAs, idPDFG, desc2 );
                            var idnull = charIDToTypeID( "null" );
                            desc1.putPath( idnull, new File( file ) );
                    executeAction( idOpn, desc1, DialogModes.NO );
            • 3. Re: Need help with openDialog
              sak1364 Level 1
              Oh my!
              I got similar results. I'm just a newbie at this - that's too complex.
              There must be an easier way. (And a more elegant way.)
              Thanks for your reply!!
              • 4. Re: Need help with openDialog
                Many things can not be scripted with Adobe DOM  you will need to learn about  Adobe Plug-in Scriptlistener.  When you see code like I posted that is not readable its Scriptlistener code that has been modified to some variables.  The code is generated by the plug-in its like and action recorder for scripts.
                I extracted what was generated for the import of an ai file that I open in Photoshop.  I replaced the hard coded file path with a var file and the hard coded document name with Name. and turned it into a function.  I did not write that code Photoshop's Plug-in Scriptlistener did... I added the code above // ===================
                and are replace two  hard coded set with var file and Name in the generated code below the  //=====================  Width and Height need work..... extract the code from mt fist post and save it as OpenAI.jsx  . Drop that file onto Photshop you should be able to open an AI file you select.
                        //alert(file);
                        var imagePath = "";
                        //alert(Name);
                                        desc2.putString( idNm, Name );                                                        // Document name  was hard code in the scriptlistener code
                                        //desc2.putUnitDouble( idWdth, idPxl, 1943.000000 );                // I opened small AI file I think the dimension was 253 px wide the dialog set 1943?
                  desc2.putUnitDouble( idWdth, idPxl, 5000.000000 );
                                        //desc2.putUnitDouble( idHght, idPxl, 276.000000 );                     // linked to width the dialog set 276  I tried both at 5000 seem to work well
                  desc2.putUnitDouble( idHght, idPxl, 5000.000000 );
                                desc1.putPath( idnull, new File( file ) );                                                   // Full file path was hard coded in the script listener code
                • 5. Re: Need help with openDialog
                  The code I wrote is a simple open dialog to select an .ai file  if one is selected open it with the function importAI  I hacked from Scriptlistener generatd code.
                  var imagePath = "";                                                          // no default path set you could set on here
                  var dir = Folder(imagePath);                                              // var dir used for folder object
                  selectAIfile = dir.openDlg("Select .ai File" , "Select:*.ai");    // open dialog for single file a title "Select .ai File" and filter "Select:*.ai" so only an ai file can be selected
                  else {
                          importAI(selectAIfile);                                               // ImportAI file selected
                  • 6. Re: Need help with openDialog
                    sak1364 Level 1
                    Wow, thanks for all the effort you put into that. I appreciate it.
                    I'm not convinced, yet, that there isn't a simpler way to do it with an Open command.
                    • 7. Re: Need help with openDialog
                      How about this:
                      var imagePath = "";
                      else {
                        //you noted the Photohop UI Open UI would open an IMPORT PDF dialog when you try ti open and .ai file
                        //that script did no open the Import PDF dialog but works and seems defauls to RGB mode, antialias etc
                        //tad you need to set antialias off abd mode to  CMYK
                        //open(File(selectAIfile));    // application Open opend like you stated.
                        //So I recorded the UI open via Scriptlistener and included the code to turn off antialias and set CMYK
                        //you stated much work however you often have to resort to Action Manager Code scripting.
                        //The Photoshop Javascript Guide I saw had open option for some file type:
                        //CameraRAWOpenOptions
                        //DICOMOpenOptions
                        //EPSOpenOptions
                        //PDFOpenOptions
                        //PhotoCDOpenOptions
                        //RawFormatOpenOptions
                        //I don't know javascript only hack at it PDFOpenOptions looked promising so I tried
                        var opts = new PDFOpenOptions();
                        opts.antiAlias = false;
                        opts.mode =  OpenDocumentMode.CMYK;
                        app.open(File(selectAIfile),opts);
                      shorteded to
                      var imagePath = "";                                                             // no defult path
                      var dir = Folder(imagePath);                                               // Declare a folder object
                      var opts = new PDFOpenOptions();                                     // Declare PDFOpenOptions
                      opts.antiAlias = false;                                                           // Antialias Faulse
                      opts.mode =  OpenDocumentMode.CMYK;                         // Mode CMYK
                      app.open(dir.openDlg("Select .ai File" , "Select:*.ai"),opts);  //Open .ai file
                      Still I prefer a separate select that allows cancel and  let you work on option for file selected. Like this:  Have a problem with size though. DPI resolution make a big change in size.
                      var orig_ruler_units = app.preferences.rulerUnits;
                      app.preferences.rulerUnits = Units.PIXELS; // Set the ruler units to PIXELS
                      var imagePath = "";
                      else {
                        //open(File(selectAIfile));    // application Open opened like you stated.
                        //you need to set antialias off and mode to CMYK
                              // Isolate File Name for document name strip moff the .ai
                              var Name =  decodeURI(selectAIfile).replace(/\.[^\.]+$/, '');   // strip the extension off
                              var imagePath = "";
                                      imagePath= imagePath + Name.substr(0, Name.indexOf("/") + 1);   // get path
                        opts.antiAlias = false; // No AnitAlias
                        opts.bitsPerChannel = BitsPerChannelType.EIGHT // 8BIT or BitsPerChannelType.SIXTEEN;
                        //opts.constrainProportions = true; // Keep original Aspect Ratio
                        opts.cropPage = CropToType.BOUNDINGBOX; // don't know if it matters with .ai file ARTBOX BLEEDBOX BOUNDINGBOX CROPBOX MEDIABOX TRIMBOX
                        //opts.height =  "6000 pixels"; // set height and with the same let constrain take care of this
                        opts.mode  = OpenDocumentMode.CMYK; // Set mode to CMYK GRAYSCALE LAB RGB
                        opts.name  =  Name; // document name
                        //opts.page  = ; // true/false Don't know if page is valid for .ai file seem to be a switch Pane number and image number PDF
                        opts.resolution = 300; // I work at 300DPI the number here make a big difference in document size opened.
                        opts.suppressWarnings  = true; // Not warnings
                        //opts.typename = ; // Read Only can not be set
                        //opts.usePageNumber = ; // Don't know if page/image number is valid for .ai file
                        //opts.width = "6000 pixels";   // make width sane as height does not seem to work in cc
                        // there is a note "DEPRECATED for Adobe Photoshop CC." for constrainProportions, height and width ...................
                      app.preferences.rulerUnits = orig_ruler_units; // Reset units to original settings
                      • 8. Re: Re: Need help with openDialog
                        sak1364 Level 1
                        Thanks again for your help. I finally got it figured out. I knew there had to be a simple solution:
                            var OpenAIFile = new PDFOpenOptions; // This sets the parameters for opening the .ai file
                                OpenAIFile.antiAlias = false;
                                OpenAIFile.mode = OpenDocumentMode.CMYK;
                                OpenAIFile.resolution = 300;
                            var SelectedFilePath = File.openDialog("Select the file"); // Prompts user to select the .ai file
                            var CurrentFile = open(SelectedFilePath, OpenAIFile); // Opens the .ai file and sets parameters
                        • 9. Re: Need help with openDialog
                          This may be a little better
                          var SelectedFilePath = File.openDialog("Select the ai file" , "Select:*.ai"); // Prompts user to select the .ai file
                          if (SelectedFilePath != null ) {
