4 Replies Latest reply on Jun 18, 2014 8:33 PM by stealthrs
    Code only works if I add Extra character
    stealthrs
      Hi, so there's a bit of code I use to keep a running list of pages I need to print (puts it in a textbox), solely depending on if certain boxes are checked... Say I have 3 checkboxs, and each represents a certain page or pages to be printed...  If select each of those checkboxes, pagesToPrint (a textbox) will be populated with 9-11, 15-40, 43 of the PDF (I made up the page numbers).  If I unselect one of those checkboxes, I need the value to be removed from pagesToPrint.  So pagesToPrint should read something like 9-11, 15-40.
      The code I'm posting below WORKS, except that I have an issue having the text to remove itself from pagesToPrint when the input is just a single number AND when it's the first item in the box... Example: "43" won't remove from pagesToPrint when I unselect the textbox txt1; but if I changed it to "43 " (added space at the end), "43-44" or "43a" all would work.  So if the box read 43, 9-11, 15-40 (the integer only being first) then the 43 wouldn't remove if the corresponding checkbox were unselected.... If it were populated with 9-11, 15-40, 43 (the range being first) then the 43 would remove if the corresponding checkbox were unselected
      Why is that??
      // script start - Trying to debug a removal issue on txt1 when integer lacks a space, symbol, or letter
      //get the button
      var btn = this.getField("txt1");
      //app.alert("value = "+btn.value);
      // this variable would change for each check box to the pages you want printed.
      var pagesToPrint = "43";
      //check value of checkbox
      if(btn.value=="Yes") {
        var action = "add";
      else
        var action = "";
      updatepagesToPrint(pagesToPrint, action);
      function updatepagesToPrint(pagesToPrint, action) {
        //app.alert(pagesToPrint + " :: " + action);
        // get the text field
        var printField = this.getField("pagesToPrint");
        if(action=="add")
        // check if the field is empty
        if ( printField.value == "" || printField.value == " ")
            printField.value = pagesToPrint;
        else
            // as printField has a value, add the new pages to the end of the value
            printField.value = printField.value + ", " + pagesToPrint;
        else
        printField.value = printField.value.replace(pagesToPrint+", ", "");
        printField.value = printField.value.replace(pagesToPrint, "");
        printField.value = printField.value.replace(/^,|^, |, $|,$/, "");
      // script end
