0 Replies Latest reply on Jun 11, 2014 9:37 PM by creativejoan0425
    Dropdown List with Submenu?
    creativejoan0425
      Hi, I have a dialog with dropdown list, my dropdown name get from a desktop folder called Testing, and since my dropdown list are too long, can dropdown make a submenu like below?
      Here is my script:
      main();
      function main(){
        var myObject;
        //Make certain that user interaction (display of dialogs, etc.) is turned on.
        //app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
        if(app.documents.length > 0){
        if(app.selection.length > 0){
        switch(app.selection[0].constructor.name){
                      case "TextFrame":
                      case "Character":
                      case "Word":
                      case "TextStyleRange":
                      case "Line":
                      case "Paragraph":
                      case "TextColumn":
                      case "Text":
                      case "Cell":
                      case "Column":
                      case "Row":
                      case "Table":
                      alert("Please insert a insert point, and try again!");
                      exit();
                      break;
        case "InsertionPoint":
        myDisplayDialog();
        break;
        default:
        //Something was selected, but it wasn't a text object, so search the document.
        //myFindChangeByList(app.documents.item(0));
                          //alert("Nothing Selected, Please Select Text Frame or Text.");
        else{
        //Nothing was selected, so simply search the document.
        else{
        alert("No documents are open. Please open a document and try again.");
      function myDisplayDialog(){
        var myObject;
        var myDialog = app.dialogs.add({name:"Testing"});
        with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
        with(dialogColumns.add()){
        staticTexts.add({staticLabel:"Search Range:"});
        }//end of with(dialogColumns.add())
        var mySearchButtons = radiobuttonGroups.add();
        with(mySearchButtons){
        radiobuttonControls.add({staticLabel:"All Opened Document   ", checkedState:true});
        radiobuttonControls.add({staticLabel:"Current Document"});
        } //end of with(mySearchButtons)
      //  New Add 20140518 (Line 84 to 103) ----------------------------------------------------------------------------------------- ------------------
        with(borderPanels.add()){
        staticTexts.add({staticLabel:"Choose:"});
        var myPDFOptionButtons = radiobuttonGroups.add();
        with(myPDFOptionButtons){
        radiobuttonControls.add({staticLabel:"Option A", checkedState:true});
        radiobuttonControls.add({staticLabel:"Option B"});
                          }// end of with(myPDFOptionButtons)
                          }//end of borderPanels
      //  New Add 20140604 Job Dictionary function  ----------------------------------------------------------------------------------------- ------------------
                      staticTexts.add({staticLabel:"Please Choose: "});
                     var myFileName = "";
                     var myFileName2 = "";
                     var myFileName3 = "";
                     var myFileName4 = "";
                     var myFileName5 = "";
                     var myDictPath =  new File('~desktop/Testing/A-E');
              //       var myDictPath2 =  new File('~desktop/Testing/F-J');
                 //    var myDictPath3 =  new File('~desktop/Testing/K-O');
                  //   var myDictPath4 =  new File('~desktop/Testing/P-T');
                   //  var myDictPath5 =  new File('~desktop/Testing/P-T');
                     var myDictFolder = Folder(myDictPath);
                     var myDicttext = myDictFolder.getFiles();
                      for (var i = 0; i < myDicttext.length; i++) {
                      var sourceChild = myDicttext[i];
                      if (sourceChild instanceof File && sourceChild.name.match(/\.txt$/i)) {
                      myFileName += " " +sourceChild.name.replace(/\.txt$/i, "");
        }//end of if
              }//end of loop
                  var myDictNameList = myFileName.split(" ");
                 //var myDictValue= [1,2,3];
                  var myDropdowns = dropdowns.add({stringList:myDictNameList, selectedIndex:0});
                //  myDropdowns.unshift("- Select Preset - ");
              }//end of with(dialogRows.add()) Line 98
                      staticTexts.add({staticLabel:"Highlight Color: "});
                      var myColor = ["Gold", "Yellow", "Black"];
                      var myColorValue = [UIColors.GOLD, UIColors.YELLOW, UIColors.BLACK];
                      var myDropdowns = dropdowns.add({stringList:myColor, selectedIndex:0});
        }//end of with(dialogRows.add()) Line 117
          }//end of dialogColumns Line 87
          }//end of dialogRows Line 75
          }//end of dialogColumns Line 74
      var myResult = myDialog.show();
        if(myResult == true){
        switch(mySearchButtons.selectedButton){
        case 0:
                      myObject = app.documents.everyItem();
        break;
        case 1:
                  myObject = app.documents.item(0);
        break;
        }//end of switch
      switch(myPDFOptionButtons.selectedButton){
        case 0:
                  alert("Option A");
                break;
        case 1:
                  alert("Option B");
          break;
        }//end of switch
        myDialog.destroy();
        }//end of if my result
        else{
        myDialog.destroy();
        }//end of else
      }// end of function
