4 Replies Latest reply on Jun 21, 2014 1:17 AM by AdobeScripts
    vbscript cs2 characterstyle
    BCRandCo
      I am trying to update a script from 2.0 to CS2 and the script is stopping at the second of the following lines. I have had no luck trying to find out what the new command should be.
      Thanks.
      Michael
      Set myPoint = tempFrame.ParentStory.InsertionPoints
          myPoint.Item(myPoint.Count).CharacterStyle = myDocument.CharStyles.Item("Style 16")
        • 1. Re: vbscript cs2 characterstyle
          RobertKyle Level 2
          Have you tried myPoint.item(myPoint.Count-1)?
          It's been a long time since I've written any VB script, but I think it's like Javascript in that items in a list are numbered from 0 to whatever. So the last item in a 10-item list is item(9).
          I think I remember that VB provides an option to start numbering at 1, if that's more convenient. Your 2.0 script might have invoked that option.
          • 2. Re: vbscript cs2 characterstyle
            BCRandCo Level 1
            Thanks for your reply. Sorry, I never mentioned the error message:run-time Error 438: object doesn't support this property or method. I have two different text styles in this textframe. In textframes where there is only the default style and I don't have to set a character style, the text is added correctly. The -1 didn't change anything. :-(
            Michael
            • 3. Re: vbscript cs2 characterstyle
              BCRandCo Level 1
              Problem solved. from 2.0 to CS2, CharacterStyles became AppliedCharacterStyles and CharStyles became CharacterStyles
              • 4. Re: vbscript cs2 characterstyle
                AdobeScripts Level 3
                In VB items are indexed from "1" - not from "0".
