8 Replies Latest reply on Jun 18, 2014 12:31 PM by A.T. Romano
    How do I combine several mov files into a larger mov file?
    normnoe
      I am just getting started with Premiere Elements (12.0) and have what seems to me to be a very simple goal.  I have several short ".mov" movies and would like to combine them into a single ".mov" movie.  I have gone through the menus and can't find a way to do this.  If someone would point me in the right direction, I'd appreciate it.
        • 1. Re: How do I combine several mov files into a larger mov file?
          Just like laying bricks on a foundation, you put one brick (file) after the other on your foundation (timeline)
          The Elements Tutorial Links Page http://forums.adobe.com/thread/1275830 may also help
          • 2. Re: How do I combine several mov files into a larger mov file?
            A.T. Romano Level 7
            normnoe
            On what computer operating system is your Premiere Elements 12 running on? Have you gone to the 12.1 Update yet?
            Now for the matter at hand...
            1. What are the properties of these .mov files going into one project....same? If different formats, we select one and then fit
            the others into it since Premiere Elements offers only one project preset.
            2. You or the program set the project preset to match the properties of the source media.
            3. You import the source media into the project. If these are files saved to the computer hard drive, then Add Media/Files and
            Folders/Project Assets from where you drag the video to the Timeline.
            4. Then, edit, add effects, etc
            5. Publish+Share to burn to disc or export to a file saved to the computer hard drive.
            Several gaps in the above that need to be supplemented with your details to come.
            But I wonder...are you really asking about disc menu preparation with regard to a multi movie Timeline?
            Please review, consider, clarify.
            We will be watching for your follow up.
            Thank you.
            ATR
            • 3. Re: How do I combine several mov files into a larger mov file?
              normnoe Level 1
              ATR and JTS,
              Thanks to both of you for your help!  I had been able to combine several
              ".mov" files into a single file, with transitions.  The problem was saving
              it as a ".mov" file.  When I saved using the defaults, I got a ".f4v" file
              which I couldn't read using Windows Media Player.
              I still can't save as a ".mov" file but the reference to presets proved
              quite helpful and after quite a bit of experimenting I was able to save as a
              ".mpg" file that works well on my PC.  Here are the details:
              I'm using Windows 7 Home Premium SP1 64 bit with Premiere Elements 12.0.
              My input files were created with a Canon camera, 1920x1080, 24
              frames/second.
              The preset that works well for PC viewing is "HDTV 1080p 24 High Quality."
              I was hoping to also be able to view the combined file on our TV (Sony 720p
              with a Panasonic Blu-ray player) but it didn't work.  Maybe I just need to
              experiment with other presets.
              Thanks again for your help.  If you have any further thoughts that you think
              would be helpful, I'd appreciate them.
              Norm Noe
              • 4. Re: How do I combine several mov files into a larger mov file?
                A.T. Romano Level 7
                Norm Noe
                Thanks for the reply.
                There is no reason why you should not be able to export your Timeline content to a file with a .mov file extension with several choices for video compression.
                From your details, I suspect I know the problem that has not surfaced until your latest post.
                When you get to Publish+Share/Computer, there are several choices. Adobe Flash Video with one of its export f4v is a choice not the default for the exports under Publish+Share/Computer. The categories to select from under Publish+Share/Computer include, from top to bottom...
                Adobe Flash Video
                MPEG
                AVCHD
                XAVC=S
                AVI
                Windows Media
                QuickTime
                Audio
                It is the QuickTime choice which will give you the exports with the .mov file extension. And, you can select from a large number of video codecs to go with the .mov file extension. But, to make that choice, you need to
                (a) Have the latest version of QuickTime installed on your computer
                (b) Use the scroll bar to the right of the list to get to the bottom of the list where you will find QuickTime.
                Example for you to look at if you have not already...if your source is 1920 x 1080p24...
                Then
                Import....
                Project Preset
                NTSC
                DSLR
                1080p
                DSLR 1080p 24
                Export
                Publish+Share
                Computer
                QuickTime
                with Presets = NTSC DV 16L9
                then, under the Advanced Button/Video Tab, customize the Export Settings...See screenshot below
                Leave the Bitrate Settings without the check mark next to "Limit Data Rate to" for this first run.
                Depending on the file size of the export, next time we can type a specific data rate value in that field.
                Please review, consider, and then let us know if you are OK with the information provided.
                Thank you.
                ATR
                • 5. Re: How do I combine several mov files into a larger mov file?
                  normnoe Level 1
                  Thanks, ATR, it worked!  And I was very happy with the quality of the
                  export!
                  However, as you hinted, the exported file was large, almost 5 times the
                  total size of the imported files.
                  The imported video data rates were all about 35000 kbps, and the exported
                  video data rate was 168710 kbps.  Should I limit the data rate to 35000
                  kbps?  Or should I limit it to 35229, the largest of the imported rates?  Or
                  should I use some other limit?
                  Thanks again for your advice and help!
                  Norm Noe
                  • 6. Re: How do I combine several mov files into a larger mov file?
                    A.T. Romano Level 7
                    Norm Noe
                    Very great news. Thanks for letting us the outcome.
                    We need to find a compromise between bitrate, file size, and quality.
                    35000 kbps (34 Mbps) may be too high. But, give it a try.
                    (kbps = kilobits per second; Mbps = megabits per second)
                    I would probably start with 14000 kbps (13.67 Mbps) and work up or down from there.
                    So, check mark next to "Limit Data Rate To _____kbps" and then type in 14000.
                    Looking forward to outcome when you get the chance.
                    Thanks again for the follow up. Much appreciated.
                    ATR
                    • 7. Re: How do I combine several mov files into a larger mov file?
                      normnoe Level 1
                      Thanks again, ATR,
                      First I tried a data rate of 14000, as you suggested, and the results looked
                      good.
                      Then I tried 35000, like the imported data rates, and the results were a
                      little bit better.  In general, the exported file size seems to be almost
                      directly proportional to the data rate.  When I used the imported data rate
                      for the exported file, the exported file was a little bigger (about 4
                      percent) than the sum of the imported files.  My guess is that this was at
                      least partly due to a little overhead caused by the transitions.
                      Finally I tried 33000 and, at least at a glance, I couldn't see any
                      difference in quality between it and the 35000.  The 33000 export was
                      slightly smaller than the sum of the imported files.
                      So now, thanks to your information, I have the ability to trade off quality
                      and file size.  When the quality is not that important, I can reduce the
                      data rate and get smaller file sizes.  When I want the best quality that I
                      can get, I'll use a larger data rate.
                      Again, many thanks!
                      Norm Noe
                      • 8. Re: How do I combine several mov files into a larger mov file?
                        A.T. Romano Level 7
                        Norm Noe
                        Your follow up with details is much appreciated and will be helpful to all.
                        We are very pleased that you have added flexibility in your projects related to Bitrate and that you are moving forward in your Premiere Elements projects. Great job.
                        Best wishes
                        ATR
