1. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
Steve Werner Jun 12, 2014 10:21 AM (in response to Ceencha)Not possible. It's a property of a TEXT FRAME.
2. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
SRiegel Jun 12, 2014 10:22 AM (in response to Ceencha)It can't be part of a Paragraph Style, because then how would InDesign know what to do with two paragraphs in the same text box that had conflicting settings? What you can do is add it as part of an Object Style for your text box. The Object Style can include a Paragraph Style.
3. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
Ceencha Jun 12, 2014 10:31 AM (in response to SRiegel)Thanks! Can "object style" be applied by a keyboard shortcut?
4. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
SRiegel Jun 12, 2014 10:34 AM (in response to Ceencha)Yes, you can assign a shortcut in the Object Style definition.
7. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
SRiegel Jun 12, 2014 11:33 AM (in response to Ceencha)What's not working? It doesn't look like you've included your Paragraph Style in the Object Style yet.
8. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
Ceencha Jun 12, 2014 11:43 AM (in response to SRiegel)I wanted to be able to apply this OBJECT STYLE to a text box, but it has no effect for some reason …
9. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
Ceencha Jun 12, 2014 11:45 AM (in response to SRiegel)Wow … it will apply PARAGRAPH styles, but NOT the vertical align.
I've spent all day trying to get this to work … a bug maybe?
10. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
SRiegel Jun 12, 2014 11:56 AM (in response to Ceencha)Your paragraph is not aligning to the top of the text frame? In my experience, align to top is the default.
11. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
John Mensinger Jun 12, 2014 12:11 PM (in response to Ceencha)Ceencha wrote:
...but it has no effect for some reason …
What do you expect to happen that isn't happening?
12. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
Ceencha Jun 12, 2014 1:19 PM (in response to John Mensinger)I desire to assign "VERTICAL JUSTIFICATION" as "TOP"
13. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
Ceencha Jun 12, 2014 1:20 PM (in response to SRiegel)no, "CENTER" is default
14. Re: Can "vertical justification" be placed in a paragraph style? In Design CS 5.5
P Spier Jun 12, 2014 1:28 PM (in response to Ceencha)The only way center would be the default is if you set that with no text frame selected.
Dollars to donuts your text frames have "Basic Text Frame" assigned already as the object style, so it wouldn't hurt a thing to edit that style the way you want it.
