1. Re: enlarge .svg diagram for printing
Larry G. Schneider Jun 12, 2014 12:49 PM (in response to Angela French)Sounds as if there is a clipping mask which is not getting enlarged. Do a Select All and then Object>Path>Clipping Mask>Release. see if that helps.
2. Re: enlarge .svg diagram for printing
Angela French Jun 12, 2014 1:02 PM (in response to Larry G. Schneider)Hi Larry, thanks for taking a stab at it. However there is no Clipping Mask menu item under Object > Path. Not even a grayed out one. I did find Object > Clipping Mask > Release, but the only option that was actionable was "Make". The Release was grayed out. I assume that means I have no clipping mask that is interfering with my printing.
3. Re: enlarge .svg diagram for printing
Larry G. Schneider Jun 12, 2014 1:23 PM (in response to Angela French)Can you post a screenshot of the file in outline mode?
4. Re: enlarge .svg diagram for printing
Angela French Jun 12, 2014 1:55 PM (in response to Larry G. Schneider) -
5. Re: enlarge .svg diagram for printing
Larry G. Schneider Jun 12, 2014 2:29 PM (in response to Angela French)What does it show at 6%? I'm having a hard time trying to figure out the size of what is being shown.
6. Re: enlarge .svg diagram for printing
Angela French Jun 13, 2014 10:29 AM (in response to Larry G. Schneider)I was able to go into the default program (Gliffy.com) and increase the size of the diagram there before exporting as .svg and that solved my issue.
7. Re: enlarge .svg diagram for printing
Larry G. Schneider Jun 13, 2014 10:47 AM (in response to Angela French)Glad you got it to work.
