1. Re: DIY LMS for Captivate
TLCMediaDesign Jun 13, 2014 5:35 AM (in response to I_don't_believe_it!)You would not be able to use SCORM or any of the automatic features for tracking in Captivate. Writing your own LMS for SCORM would be very difficult.
Moodle is free and there are one-click installations.
If all you want to do is record those few things then I'm sure it would be too difficult to trigger and store that information in a DB. We have done many courses (in SCORM) where we do not use Captivate to make any SCORM calls and publish the Captivate files normally with no Quiz settings or SCORM.
2. Re: DIY LMS for Captivate
Erik Lord Jun 13, 2014 6:11 AM (in response to I_don't_believe_it!)There's a lot too SCORM. As has been mentioned, it surely wouldn't be 'easy'. How difficult it is though depends on just how skilled you are a programming such things...
I'd agree Moodle may be the quickest option to try. You can also record results without an LMS - i.e. to Acrobat.com, or a custom tracking PHP/DB setup (which is probably more what you're trying to do), or even to Google Docs...
Adobe Captivate * Report to Acrobat.com or internal server
http://captivatedev.com/2012/11/12/adobe-captivate-6-x-widget-google-lms-with-email-report ing-2/
3. Re: DIY LMS for Captivate
I_don't_believe_it! Jun 14, 2014 8:13 AM (in response to I_don't_believe_it!)Thanks for the replies. It is the custom tracking I was wondering about when all that is required is to track completion status. I am pretty sure I saw a post on the forums about doing this but could not find it again!
4. Re: DIY LMS for Captivate
Erik Lord Jun 16, 2014 6:26 AM (in response to I_don't_believe_it!)Yes, any of the tracking options Captivate provides can be used to 'track completions'.
The biggest issue may be, how do YOU (or whomever cares) find out about those completions? How do you run reports?
LMS products make that pretty easy (usually). Custom tracking can make it more complicated and can require you to create a custom reporting tool.
The Captivate Quiz Results Analyzer is meant to be the reporting too for such non-LMS solutions...but will it work well for your needs?
5. Re: DIY LMS for Captivate
I_don't_believe_it! Jun 27, 2014 6:50 AM (in response to Erik Lord)Thanks for the advice
