5 Replies Latest reply on Jun 18, 2014 6:38 AM by somnamblst
    Can't nest slideshow without breaking it
    somnamblst Level 1
      I just want to say that coming from Flash I find Edge Animate frustrating.
      I found this slideshow tutorial that uses the following code on Creation Complete on the stage
      http://designupdate.com/blog/2013/07/23/how-to-create-a-slideshow-in-edge-animate/comment- page-1/
      var imageCount = 1;
      var numOfPhotos = 7;
      sym.$("textTotal").html("of " + numOfPhotos);
      sym.showPhoto = function (photoDirection){
        imageCount = imageCount + photoDirection;
        //Beyond 22, change to 1
        if (imageCount > numOfPhotos){ imageCount = 1};
        //Less than 1, change to the very last photo
        if (imageCount < 1){ imageCount = numOfPhotos};
        //Change the text number to the current photo
        sym.$("textCount").html(imageCount);
           //Fade out the current photo
           sym.$('mainPhoto').fadeOut('slow', function() {
                //Set the attribute to the correct photo
                sym.$("mainPhoto").attr('src', 'images/photo_'+imageCount + '.jpg');
                sym.$("mainPhoto").load(function () {
                //Fade in the new photo
                sym.$('mainPhoto').fadeIn('slow');
      For my purpose, I have to use a template that shows one of 3 different symbol sizes, based on a user's view port. Nothing I have tried, does not break the functionality of the arrow images swapping images. ThoughI am getting a cursor.
      I have tried the stage, inside one of the symbols, and converting it to a symbol, both on the stage and inside one of the symbols.
      The arrow buttons have this code
      sym.getComposition().getStage().showPhoto(-1);
      Any suggestions welcome.
        • 1. Re: Can't nest slideshow without breaking it
          jbowden Adobe Employee
          Hi there,
          First question: did you change the tag on your mainPhoto element from div to img? That's the only way you'd be able to change the source.
          Not sure I fully understand this. Did you convert the mainPhoto element into a symbol? If so, you'll have to get the symbol on your creationComplete handler before you can address the element. If not, please provide more detail.
          Joe
          • 2. Re: Can't nest slideshow without breaking it
            somnamblst Level 1
            Thanks Joe.
            mainPhoto is an img, I didn't need to change it.
            I did try making the slideshow (textTotal, textCount, back, next, mainPhoto layers into a symbol, placed both on the Stage and inside the Large_Symbol symbol.
            I have tried adding the code above, both above and below the creation complete code that shows one of three symbols based on viewport. I tried adding it as a play event. I tried adding it to the symbol Large_Symbol as Creation Complete and as a symbol on the Large_symbol timeline with the code added to the symbol and inside the slideshow symbols timeline..
            I tried pathing to the symbol like this on the forward next buttons
            sym.getComposition().getStage().getSymbol('Large_Symbol').getSymbol('imageFades').getimage .showPhoto(-1);
            and as
            sym.getComposition().getStage().getSymbol('imageFades').getimage.showPhoto(1);
            because I noticed when I edit imageFades it shows it as a child of Stage, even though I placed it on the Large_Symbol timeline.
            Is there no equivalent to load Movie in Animate?
            • 3. Re: Can't nest slideshow without breaking it
              somnamblst Level 1
              Found this in the API
              I was thinking I could put this in the Creation Complete code on the stage. My slideshow symbol is called imageFades
              sym.getComposition().getStage().getSymbol("Large_Symbol").getSymbol("imageFades").play();
              still no luck
              I wish I could just load the slide show as a separate Animate file
              • 4. Re: Can't nest slideshow without breaking it
                Hi again,
                By default, when you import an image file into Animate or place one from the Library to the Stage, it is placed into a div container. Unless you specifically change the tag type from div to img (in the Properties panel), you won't be able to replace the src through code.
                hth,
                Joe
                • 5. Re: Can't nest slideshow without breaking it
                  somnamblst Level 1
                  Thanks for checking back.
                  I guess I am confused by that. mainPhoto, which is where the subsequent images appear is not a div, it is an image. It was not something I could change to see if that would work. It is photo_1, the rest of the photos are loaded like an array by name. photo_2, photo_3, etc.
                  In addition to MainPhoto, there are the next and previous arrows and dynamic text fields, for textCount and textTotal. back and next are divs, and back and next are what changes which photo you see
                  I currently have this on next
                  I added .getSymbol('imageFades').
                  Because
                  sym.getComposition().getStage().getimage.showPhoto(1); did not work
                  nor did
                  sym.getComposition().getStage() getSymbol(Large_Symbol).getSymbol('imageFades').getimage.showPhoto(1);
                  My Flash experience makes me say where is _root.
