1 Reply Latest reply on May 11, 2007 6:56 AM by Devdoc
    Load Movie if XML.text = 16
      Hi everybody :D, Hope you can help me here ...
      Should be fairly simple but I cant get my movies to load depending on the dynamic XML data which I load into dynamic text boxes ... check this out :D
      thanks for your help !!!
        • 1. Re: Load Movie if XML.text = 16
          Devdoc
          hey!
          The most common problem here is trying to use the values before they have loaded. Without checking your code too closely i suggest you try calling the weatherMovieLoader function from inside the onLoad handler. That way you will be sure the values you are trying to use have been loaded and are available.
