2 Replies Latest reply on May 10, 2007 4:59 AM by bjanun
    Intersects
    uneus
      I have game where a small monster is fooling around between some small houses. He should not be capable to walk trough the houses and because of that I use intersects to avoid the different sprites where the buildings are. But every sprite who is downwards the middle of the sceen, he can walk trough, not from sides just from the top. Why?
        • 1. Re: Intersects
          Charles Parcell Level 1
          I assume that sprite(3) is the monster and sprite(2) is the house. If this is the case then it would seem that is the monster "attacks" the house either from the left or top, he will then be moved even further into the house. This will continue until the monster is exits to the south east.
          The problem is the +5 you have on the end of each of those lines of code.
          What you want to do is capture the monsters location FIRST, then try and move him in whatever direction he is walking. If that results in an intersect, then move him back to the captured location and pick a new direction.
          Hope this helps.
          • 2. Re: Intersects
            bjanun
            Thank´s a lot that helped me and solved the problem
