2 Replies Latest reply on Jun 16, 2014 8:32 AM by ShaylynJ
    validate required fields before using custom email button
    ShaylynJ
      Good Morning,
      I have a custom button that I am using as a email button so we could have a cc address added. The code I'm using is:
      form1.subform.Button3::click - (JavaScript, client)
      var oDoc = event.target;
      oDoc.mailDoc({
      bUI: true,
      cTo: "test@email.com",
      cCc: "cc@email.com",
      cSubject: "Title of the form",
      Is there a way I can validate that 3 text fields are filled in when the user clicks the button?
      Thank you for any help you can provide.
        • 1. Re: validate required fields before using custom email button
          Magus069 Level 4
          to verify if a field is filled in you may use the if statement to check if the rawValue is null
          var boValidation = true;
          if (textfield1.rawValue == null){
               //Validation failed
               boValidation = false;
          if null is not working it might be because it's a checkbox or radiobutton or dropdownlist, etc... cehck if value is 0
          if (chkBox.rawValue == 0){
               //Validation failed
          Now when you are about to send the email verify is the fields were filled in successfuly
          if (boValidation){
               oDoc.mailDoc({
                    bUI: true,
          • 2. Re: validate required fields before using custom email button
            ShaylynJ Level 1
            Thank you it worked! Code used for reference:
            if (form1.subform.name.rawValue == null || form1.subform.userid.rawValue == null || form1.subform.compname.rawValue == null)
            //Change validation to null
            app.alert("Please fill in the required fields.");
            if (boValidation)
            oDoc.mailDoc({
            bUI: true,
            cTo: "t...@domain.com",
            cCc: "c...@domain.com",
            cSubject: "title",
