2 Replies Latest reply on Jun 16, 2014 2:13 PM by zalmanf
    Vertical Justification doesn't work when anchored object is present (inDesign CC)
    zalmanf Level 1
      I am not sure if this is a bug or not, but i converted a file from inDesign CS5 that used text frames with the vertical justification set to "justify" (to align the bottoms of two side by side text boxes) - and this worked correctly, but after I converted it to inDesign CC, i noticed that the text was no longer justified.
      After some troubleshooting, it seems that having an anchored object with a text run-around anywhere in the frame makes it ignore the "justify" option and it becomes "top" aligned.
      Is this a "bug or a feature" and is there a workaround i can use to avoid reflowing a 600 page book?
      Thanks!
