3 Replies Latest reply on May 15, 2007 5:46 AM by JoeDaSilva
    CMYK from fireworks doc
    Level 7
      So the Fireworks help says that before sending a fireworks document to a
      printer that requires CMYK, that we should be able to import our work into
      Freehand... which I did, and sent that to the printer, but the printer
      still insists that they're RGB in design. Can anyone help shed more light on
      this???
        • 1. Re: CMYK from fireworks doc
          Level 7
          > this???
          _adrian,
          How did you get the file out of Freehand? Export? Save As?
          There is a 'Setup' button on the dialog box that opens when you save or
          export. If you open 'Setup' there is an option to convert colors to
          CMYK, RGB or CMYK and RGB.
          SKB
          • 2. Re: CMYK from fireworks doc
            Level 7
            Hmm.. its been a couple of weeks, so I don't remember.. will have to try
            again. How can i confirm the conversion after its done?
            Thx
            • 3. Re: CMYK from fireworks doc
              JoeDaSilva Level 4
              If you have Photoshop, it'll tell you the color mode right in the top bar to the right of the document name. I haven't used Freehand in years though, so I'm not sure how to tell there.
