4 Replies Latest reply on Jun 17, 2014 3:53 PM by Meervaldo!
    Locating roll over text field.
    Meervaldo! Level 1
      I created an interactive pdf in InDesign with a video clip embedded. Rolling over the still image I get a text field pop up with name of image. I need to edit that name/text, where do I go in InDesign? The text field is only visible in the pdf when I roll over the image. I have searched through the Buttons, Animation & Media windows in InDesign but can't locate the field in question. I created it 2 years ago, hence the blank mind!
      Meervaldo!
        • 1. Re: Locating roll over text field.
          Meervaldo! Level 1
          16 views and no replies, maybe it needs further clarification. This image shows a detail from a page. If I move the cursor inside the blue frame the text field 'Click to activate' appears. I need to edit this text but can't find where to do this in InDesign. Blue frame contains a link to a video clip and features a still image from the video. Its not a button, otherwise I would be looking at button states and rollovers.
          Thanks, do help!
          • 2. Re: Locating roll over text field.
            Steve Werner Adobe Community Professional & MVP
            The answer is that it is nothing InDesign (or you) did. You're looking at the default player of an Adobe Reader or Acrobat when it encounters a video.
            If it were an image, you could add a Tool Tip, by choosing from the Media panel menu > PDF Options > Description.
            However, for whatever reason, you apparently can't override that particular message in any way I can figure out. You can view  the video properties in Acrobat by right-clicking on the video and choosing Properties. But I don't see a property to edit the message.
            • 3. Re: Locating roll over text field.
              Meervaldo! Level 1
              Many thanks Steve,
              I spent a long time looking at this issue and thought I had just missed a trick by forgetting something. But it appears I didn't, and I also won't be able to translate it to the irish language either!
              • 4. Re: Locating roll over text field.
                Meervaldo! Level 1
                I confirmed what you suggested by placing another video file on the same page and exporting to PDF. Same thing occurred, same activation text appeared. I did find a much older copy of the file which used the mpeg format for the video, it did not display the text. So I am putting it down to a software update since first created.
                Many thanks again.
