1. Re: Select unused items in Library?
sudeshna sarkar Jun 17, 2014 8:10 PM (in response to rossfranks)Hi ,
You can go to the "images" folder of your project and delete the images you don't want and they would be removed from the library. Take a look at this thread : delete images from Library
Thanks and Regards,
Sudeshna Sarkar
2. Re: Select unused items in Library?
rossfranks Jun 17, 2014 8:43 PM (in response to sudeshna sarkar)Hmm thanks sudeshna sarkar,
not a great solution if I'm using 500 hundred images and for some reason 100 aren't being used anymore and I don't want to manually re-add them, that would be very time consuming.
3. Re: Select unused items in Library?
sudeshna sarkar Jun 17, 2014 8:57 PM (in response to rossfranks)I understand but we don't have this option directly available in Edge Animate as we have it in Flash Pro to delete all unused items from the library. The solution I mentioned is just a workaround and isn't that great
Regards,
Sudeshna
4. Re: Select unused items in Library?
rossfranks Jun 17, 2014 9:01 PM (in response to rossfranks)Ok thanks sudeshna sarkar,
I'm just trying to work out whats the best way to manage frame be frame SVG animations, this was one of the issues I was having.
5. Re: Select unused items in Library?
harborphil Jul 7, 2014 10:44 AM (in response to rossfranks)I would like to add my concerns to this discussion. If an Animate user is not careful, ALL of the library files will be uploaded to a website's host server whether they are needed or not. It would be nice to have a "delete" process directly within the library panel. Or, it would be nice to have a fresh, empty library with each new Animate project (no carryover of past files).
6. Re: Select unused items in Library?
Joe Bowden Jul 7, 2014 1:42 PM (in response to harborphil)Hi there,
Thanks for your feedback - Library workflow concerns have been noted and are on our radar.
Not sure I understand this. If you create a new composition and save it in a new directory, there should be no assets in your Library. The only ways what you're describing can happen is if you do a SaveAs on a composition that already has Library assets, or if you save into a directory that already has an images folder containing assets.
If you're not seeing what I'm describing, can you please add further detail?
Joe
