1. Re: Export keyed footage with a Transparent BG ?
Dave LaRonde Jun 18, 2014 5:09 PM (in response to Netcommercial)Looks like you already pulled the key. You're ready to render in a media container & codec that will support alpha channels. Personally, I'd use quicktime movies in the PNG codec. Add the comp to the render queue, and in the output module, set it up for PNG, RGB+Alpha, Millions Of Colors +, and Straight (NOT Premultiplied).
2. Re: Export keyed footage with a Transparent BG ?
Netcommercial Jun 18, 2014 5:12 PM (in response to Dave LaRonde)I was doing that with an AVI out . I thought I was doing it right... maybe since I shut it and re-open it I will get Joy...
3. Re: Export keyed footage with a Transparent BG ?
Dave LaRonde Jun 18, 2014 5:19 PM (in response to Netcommercial)Now, just because I see a black background where green once was doesn't mean it's actually transparent. Have you double-checked?
4. Re: Export keyed footage with a Transparent BG ?
Netcommercial Jun 18, 2014 5:24 PM (in response to Netcommercial) -
5. Re: Export keyed footage with a Transparent BG ?
Netcommercial Jun 18, 2014 5:29 PM (in response to Netcommercial) -
6. Re: Export keyed footage with a Transparent BG ?
Rick Gerard Jun 18, 2014 6:21 PM (in response to Netcommercial)There is a preset for lossless with alpha in the render cue.
Your screenshot does not show the info for the bottom layer of your footage. We don't know what format you used. Just try the default lossless with alpha preset and see what you get. This kind of problem is always user error somewhere along the line.
7. Re: Export keyed footage with a Transparent BG ?
Netcommercial Jun 18, 2014 7:23 PM (in response to Rick Gerard)I do not have that option for a drop down. Maybe I somehow (as you elude to) operator error? Here is two grabs and a recorder of my option here. The pics show vid switch ON in one, and BOTH with Transparency ON. The other is with the vid switch off to show transparency. The third pic are my options for Templates Edit>Output>
8. Re: Export keyed footage with a Transparent BG ?
Netcommercial Jun 18, 2014 7:39 PM (in response to Netcommercial)
