0 Replies Latest reply on Jun 18, 2014 11:01 PM by Luc Lorent
    insert pages not working correctly
    Luc Lorent
      I have a problem regarding applescript and acrobat.
      Since there is no acrobat scripting forum, i posted it here.
      I have an applescript that runs perfectly with Acrobat pro 10.
      But now I want to run it on a computer where Acrobat pro 11 is installed and it makes Acrobat quit on the "insert pages" command.
      I installed Acrobat 11 on my mac as well and it has the same behaviour: it quits on the insert pages.
      If i use the Acrobat 10, it is still executing correctly...
      Is there an issue with this function in javascript too?
      Has anyone experienced the same problem or has a solution?
      Part of the script below:
        tell application "Adobe Acrobat Pro"
        set deneerste to open file outputFormaat
        set dentweede to open file outputPDF
        set afmetingen to media box of page 1 of document 2
        set hoogte to (item 2 of afmetingen)
        set breedte to (item 3 of afmetingen)
        if hoogte < breedte then
        set rotation of page 1 of document 2 to 90
        end if
        repeat oplage times
      --This is where Acrobat 11 quits...
        insert pages document 1 after -1 from document 2 starting with 1 number of pages 1
        end repeat
        close document 2 saving no
        close document 1 saving yes
        end tell
      Tom Usrey 2
