5 Replies Latest reply on Jun 23, 2014 1:13 AM by MICWAR
    Checkbox change value in field and reveal hidden text
    MICWAR Level 1
      Hi
      I need to change a value in a field when a checkbox is pressed
      the default value could be 10$ in "formfield1"
      But when the checbox is checked the value in "formfield1" should change to 8$
      I also need a function to reval text in "textfield2" from hidden to visible text.
      Is that even possible to combine in one checkbox?
      I found some code  in the forum and modified it but it does not work as expected, it affects field it should not and it behaves a bit funny, below is the code to calculate.
      Also i tried to change the value from Off to On, but that didnt reversed the procedure as i hoped.
      Well Its a start, maybe someone can figure it out an give me some help on the way?
      ________________________________
      // custom calculation for discount
      var nDiscount = 2;
      // sub total field name
      var cSubTotal = "formfield1";
      // non-Discount check box name
      var cbNonDiscount = "CheckBox1";
      // set default value for non-Discount
      event.value = 10;
      // see if purchase is with Discount or not non-Discount
      if(this.getField(cbNonDiscount).value == "Off") {
      event.value = this.getField(cSubTotal).value - nDiscount;
      // end custom calculating
