1. Re: how do i make web app list horizontal
Dave Black Jun 20, 2014 5:46 AM (in response to BigBroBiggs)Care to post a link to this page- it is like an HTML and or CSS issue.
2. Re: how do i make web app list horizontal
BigBroBiggs Jun 20, 2014 6:08 AM (in response to Dave Black)my site is www.fatratwraps.com This is embarrassing as I have been a BC Partner since before Adobe came into the picture... so you would think that I would be giving the advice...
I fixed the issue ( I think ) but it still confuses me why what I did worked.
It starts off with the term ROW. To me in my mind a row goes horizontally. So when I set up the tag for placing the latest WebApp items I said 2 items 1 ROW thinking that it would place the 2 items on the one row.... instead it place 1 time in two rows so the items where presented one on top of the other.
I changed it to 2 items 2 ROWS and with only two items in my database it is rendering like it should... I am going to make up another item to make sure it only show the two.
3. Re: how do i make web app list horizontal
BigBroBiggs Jun 20, 2014 9:59 AM (in response to BigBroBiggs)Dave, I just added a third item...and the issue I am faced with is the pagination. I really don't want it to show any pagination JUST the last two articles... which it is showing the first to...
4. Re: how do i make web app list horizontal
Dave Black Jun 20, 2014 10:07 AM (in response to BigBroBiggs)Simply hide the pagination with this css:
ul#webapp11809pagination{
display: none;
5. Re: how do i make web app list horizontal
BigBroBiggs Jun 20, 2014 10:12 AM (in response to Dave Black)Thanks Dave, will this also affect the pagination then on the larger list page? See News page on site. www.fatratwraps.com/news.html
6. Re: how do i make web app list horizontal
BigBroBiggs Jun 20, 2014 10:14 AM (in response to BigBroBiggs)Also I figured out as you can see the issue with listing the newest first... by adding "date" at the end of the module tag as in {module_webapps,11809,a,,,,,5,,1,date}
7. Re: how do i make web app list horizontal
Dave Black Jun 20, 2014 10:25 AM (in response to BigBroBiggs)It more than likely will, therefore, since the list on the home page is inside a div with a class of 'eight', change the css like:
.eight ul#webapp11809pagination {
display: none;
Alternativley, you can add a unique class to the home page 'eight' div so you are sure there won't be any issues:
. myUniqueClass ul#webapp11809pagination {
display: none;
8. Re: how do i make web app list horizontal
BigBroBiggs Jun 20, 2014 10:31 AM (in response to Dave Black)I have directed the code using Fire Bug and then placed it along side the Pagination for the design of my template... This is for the list on the NEWS page.
Using your suggestion but in reverse could I use ...
nav .pagination ul#webapp11809pagination {
display: none;
<!-- Pagination -->
<nav class="pagination">
<ul>
<li><a href="#" class="current">1</a></li>
<li><a href="#">2</a></li>
<li><a href="#">Next</a></li>
</ul>
<div class="clearfix"></div>
</nav>
<!-- BC Generated Code
<ul id="webapp11809pagination" class="pagination webapp">
<li class="pag-current">1</li>
<li class="pag-number">
<a href="/Default.aspx?PageID=4189729&A=WebApp&CCID=11809&Page=2&Items=2">2</a>
</li>
<li class="pag-next">
<a href="/Default.aspx?PageID=4189729&A=WebApp&CCID=11809&Page=2&Items=2">Next</a>
</li>
</ul> -->
9. Re: how do i make web app list horizontal
Liam Dilley Jun 20, 2014 7:18 PM (in response to BigBroBiggs)You do not put CSS inline into HTML, it needs to go into CSS stylesheet or inline style tags. You can not put your own pagination to control html, You can only use and style the BC pagination.
