2 Replies Latest reply on Jun 20, 2014 3:16 PM by nellbern
    unlock-delete-create guides on master pages
    nellbern Level 1
      Im having issues with code below. I inherited the previous designer documents  would like to unlock, delete & create margins to the master pages. I'm no an expert but knows a little bit.
      tell application "Adobe InDesign CS4"
        activate
        set myDocument to document 1
        tell view preferences of active document
        --Set horizontal and vertical measurement units to inches.
        set ruler origin to page origin
        set horizontal measurement units to inches
        set vertical measurement units to inches
        end tell
        --change margins of the master spread
        set myMasterSpread to master spread 1 of myDocument
        tell margin preferences of page 1 of myMasterSpread
        -- page margins and columns.
        set left to ".5" --outside
        set top to ".5 in"
        set right to ".75 in" --inside
        set bottom to ".75 in"
        end tell
      --Page margins right  master page
        tell margin preferences of page 2 of myMasterSpread
        set left to ".5" --inside
        set top to ".5 in"
        set right to ".75 in" --outside
        set bottom to ".5 in"
        end tell
        --create guides on master pages 1 & 2
        --** currently not working
        tell guide preferences of page 1 of myMasterSpread
        set guides locked to false
        set ruler guides color to orange
        --tell page 1 of myDocument
        delete guides
        make guide with properties {orientation:vertical, location:".25"}
        make guide with properties {orientation:vertical, location:"7.6875"}
        make guide with properties {orientation:horizontal, location:".25"}
        make guide with properties {orientation:horizontal, location:"10.25"}
        --end tell
        tell guide preferences of page 2 of myMasterSpread
        delete guides
        end tell
      end tell
      end tell
        • 1. Re: unlock-delete-create guides on master pages
          Mary Posner Level 3
          Guide preferences are set at the document level, not at pages or spreads. You need to address the page, rather than the guide preferences of the page, to make guides. Try this:
            tell guide preferences of myDocument
            end tell
            tell page 1 of myMasterSpread
              delete guides
            end tell
          Lather, rinse, repeat for page 2 of the master spread. BTW, you can remove the "set myMasterSpread" line from under "--** currently not working" line. You already set that towards the top of the script.
          Hope that works for you.
