8 Replies Latest reply on Nov 19, 2007 7:09 AM by DSFASFASFSDAFSDZFSDA
    CFEclipse Help
    Whitetimer Level 1
      Hello All ... Ok i am having a big problem installing CFEclipse on to the standalone copy of Flex 2.0.1 .... I have followed the instructions etc and when i try and use it i get the following error ... Any suggestions ?
      quote:
      Unable to create this part due to an internal error. Reason for the failure: The editor class could not be instantiated. This usually indicates that the editor's class name was mistyped in plugin.xml.
      This is the Details .. Any help please !!!!!
      quote:
      java.lang.NullPointerException
      at org.cfeclipse.cfml.editors.CFMLEditor.initializeEditor(CFMLEditor.java:311)
      at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.<init>(AbstractDecoratedTextEditor. java:216)
      at org.cfeclipse.cfml.editors.CFMLEditor.<init>(CFMLEditor.java:253)
      at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
      at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
      at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
      at java.lang.reflect.Constructor.newInstance(Unknown Source)
      at java.lang.Class.newInstance0(Unknown Source)
      at java.lang.Class.newInstance(Unknown Source)
      at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:162)
      at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:142)
      at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:129)
      at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(C onfigurationElementHandle.java:48)
      at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:240)
      at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:69)
      at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:236)
      at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:252)
      at org.eclipse.ui.internal.EditorManager.createPart(EditorManager.java:842)
      at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:562)
      at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:384)
      at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:552)
      at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:223)
      at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2362)
      at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2295)
      at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage.java:2287)
      at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:2273)
      at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2268)
      at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2249)
      at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
      at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
      at org.cfeclipse.cfml.wizards.cfmlwizard.NewCFMLWizard$2.run(NewCFMLWizard.java:168)
      at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
      at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
      at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3102)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2761)
      at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:153)
      at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:303)
      at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:830)
      at org.cfeclipse.cfml.wizards.cfmlwizard.NewCFMLWizard.performFinish(NewCFMLWizard.java:119)
      at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:676)
      at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:349)
      at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:556)
      at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:90)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3125)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2758)
      at org.eclipse.jface.window.Window.runEventLoop(Window.java:809)
      at org.eclipse.jface.window.Window.open(Window.java:787)
      at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java: 110)
      at org.eclipse.jface.action.Action.runWithEvent(Action.java:996)
      at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:538)
      at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:488)
      at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :400)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1699)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:367)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
      at com.adobe.flexbuilder.standalone.FlexBuilderApplication.run(FlexBuilderApplication.java:1 03)
      at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:226)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334)
      at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
      at org.eclipse.core.launcher.Main.run(Main.java:973)
      at org.eclipse.core.launcher.Main.main(Main.java:948)
      Many thanks
      Whitetimer
        • 1. Re: CFEclipse Help
          dukerickroot Level 1
          I just had this exact same problem. Can anyone help us?
          • 2. Re: CFEclipse Help
            rokskrinjar
            I also have this problem. Would really appreciate any advice.
            Thanks!
            Rok
            • 3. Re: CFEclipse Help
              Whitetimer Level 1
              Hi .. I gave up trying and installed the Flex addon in Eclipse, and everything works just fine. Saved time trying to figure out the problem.
              Whitetimer
              • 4. Re: CFEclipse Help
                AlHolden Level 1
                My FB 2 just updated itself to 1.3.1.4 and did the exact same thing. I'm hosed.
                • 5. Re: CFEclipse Help
                  AlHolden Level 1
                  Help | Software Updates | Manage Configuration | CFEclipse 1.3.1.4 1.3.1.4 | Replace with previous version | 1.3.0 | (this just goes back in time - only thing I can think of while I wait for a real answer)
                  • 6. Re: CFEclipse Help
                    JimPickering
                    It is CFEclipse that is causing the issue. If you use the updater built-in to Flex Builder 2, you'll see that the CFEclipse version is 1.3.1.4 1.3.1.4. Do not install that version.
                    You will have to manually install CFEclipse until they fix the issue. I manually installed version 1.3.1.3. Download it from www.cfeclipse.org/update and then go into the zip file. You'll see two folders: plugins and features. Inside of each folder is a .jar file. Close Flex Builder 2.0.1. Copy the .jar file in plugins and paste it into FlexBuilder's plugins folder. Copy the .jar file from features and paste it into Flex Builder's features folder. Start Flex Builder again. It worked for me and should for you too.
                    • 7. Re: CFEclipse Help
                      cheftimo Level 2
                      I had the exact same problem; all these things fotoczar suggests will work, but you don't even have to do all that.
                      Download the zip file from the CFEclipse site, use the FB2 Software updates>Find and install, then in the 'Update sites to visit' dialog box, press 'New Archived Site', locate tha ZIP folder you downloaded and finish the installation.
                      Worked like a charm!
                      • 8. Re: CFEclipse Help
                        I just installed CFEclipse 1315 to my Flexbuilder 2.0. However, when I try to go to Help >Software Updates>Find and Install >Search for New Features to install, no matter what I do, I get this message:
                        Network connection problems encountered during search.
                        Unable to access " http://www.cfeclipse.org/update".
                        Unable to access site: " http://www.cfeclipse.org/update" [java.io.IOException]
                        And whenever I try to open a CFC I get the problem the guy above encountered. I have copied and pasted files from the ZIP into Flexbuilder's folders as instructed, but to no avail. The CFEclipse just does not work for me!! Any ideas?
